Sony KDL-32S3000 Six Blinks
  • fastvideo
    • Dec 2008
    • 55
    Sony KDL-32S3000 Back light tries a couple of times then shuts down with 6 red blinks all voltages seem to be good from the power supply.
    Has any one had this with this model?
    I think it may be the cf lamps no good. Any help on how to test individual cf lamps would be appreciated.
    Thank you
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sony KDL-32S3000 Six Blinks
    Thank you
    One source said that was an inverter error. Here's the service manual. You can check it out for yourself.
    If you require further assistance, I suggest following the links in my signature for information on attaching pictures. Attach (don't post inline) a good picture of the inside of the TV.
    PlainBill
    • fastvideo
      • Dec 2008
      • 55
      Source said that was an inverter error.
      But no one get the fix.
      Any help would be appreciated.
      • PlainBill
        • Feb 2009
        • 7034
        Did you check the fuse on the inverter? If that's good, how about some decent pictures of the inverter. One over-all shot of the top with the output connectors to the top of the picture, a second of the back, and one of the top showing the input connector.
        PlainBill
        • fastvideo
          • Dec 2008
          • 55
          Picture of the inverter.
          • PlainBill
            • Feb 2009
            • 7034
            Thanks. Good pictures.
            There are three fuses on this board, they are circled in red in the attached picture. Measure the resistance across each of them using the 200 ohm scale on your DMM.
            There are two ICs circled in yellow. What are the part numbers?
            PlainBill
            • Hobby 1
              • Mar 2010
              • 86
              Check the inverter transformers. Do resistance checks on the primary and secondary windings. They should all be the same. These transformers can fail, and can be bought in singles and replaced also. As for the lamps, the only way I know of is to disassemble the panel and look at the lamps as they light up, the bad one will not light up. Replace the bad lamp if found.
              • fastvideo
                • Dec 2008
                • 55
                PlainBill
                Three fuse is good. IC on left 339 top line, 2nd line EZ2J703. the numbers on the right is oz9541sn.
                Back light tries to come on then off, then shuts down with 6 red blinks.
                Tried connect each of the 8 cf lamp, same thing, light tries to turn on then off, six red blinks.
                Before the back light is on completely, protection mode kicks in then shuts down with 6 red blinks.
                • fastvideo
                  • Dec 2008
                  • 55
                  PlainBill
                  What is the possibility that the protection circuit on the power supply has problem. There is a pot to adjust, but there is no information on the service manual.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    I had a similar problem about a year ago, and tore out a lot of hair trying to solve it. By all appearances the inverter was not turning on. When I finally got my act together, I realized the inverter WAS turning on, detecting a problem, and shutting down immediately. That inverter was made by Darfon.
                    By the part number, this inverter was also made by Darfon. For whatever reason, Darfon uses a very short timeout on their inverters. The inverter is turning on, it detects a fault condition, turns off the CCFLs, and sends an error signal to the main board.
                    I suggest following Hobby1's advice. It will be difficult to check the resistance of the primaries, so check the resistance of the secondaries first.
                    PlainBill
                    • matwan
                      Sony XR-55X90J 5 blinks
                      by matwan
                      I have problem with SONY 55X90J. After several check status is as below;
                      1. Running power board as stand alone:
                      TCON_12V =~ 12.6V
                      EVDD V On Max 24V= 19V.
                      2.
                      Running power board with TCON as stand alone:
                      Effect as below, attched.
                      3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                      "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                      Best regards....
                      09-28-2025, 04:26 AM
                    • GoodCapDude
                      Sony XBR-75X940E intermittent 6 blinks error code
                      by GoodCapDude
                      Hi everyone. First post on Badcaps!
                      I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                      09-20-2025, 06:07 AM
                    • AK_777
                      Sony KD-65A1 Repair – 4 Red Blinks Error
                      by AK_777
                      Hi everyone!
                      I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                      Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                      02-20-2025, 04:15 PM
                    • dumbdd
                      Sony 75X9400E TV.. 5 Red blinks
                      by dumbdd
                      I was using this TV for 5 years before it stopped working. I like this TV and would love to fix it myself.*
                      When I press the power button, the white led comes on (sony calls the module smart core) and then it switches over to 5 red blinks. No screen, no backlight, no relay click, nothing. I have disassembled the tv and found the service manual for 75x940e online. The manual suggests a faulty power board, TCON or the panel.**
                      The standby pin is at 3.3V. Fuses on the mainboard and TCON are fine. Caps on TCON also seem to be fine. When I turn on the tv the white led...
                      07-01-2023, 08:54 PM
                    • Nicktronic
                      Sony XR-55X90J 4 blinks
                      by Nicktronic
                      Hey guys, got this Sony that turns on momentarily and then goes black with 4 blinks of the standby light. I can't find a service manual, but best guess was the Local Dimming board based on a similar TV saying LD_ERR or BCM_ERR. I found a replacement, but it didn't work. Before I put more money into replacement boards, Im wondering if anybody has seen this issue and what worked for them, or has the service manual for this specific TV.
                      Thanks!...
                      02-13-2024, 07:01 PM
