alright when i baught this projector it would not power on. when power was applied it would just click. then whan the power was pulled off it would click again. im guessing from a short. anyway i tested all of the caps and 2 were obviously way out of its recommended esr value. i replaced those 2 caps and since there wasnt a ton of other caps on there i went and replaced the rest of them as well. i finished the job today and went to plug it in. the indicator lights come on and then a whistle starts to come from the unit. the lamp then powers on but acts weird as the brightness of the light changes in pace with the intensity of the whistle?...any ideas guys?
InFocus Projector
Tags: None
Re: InFocus Projector
2. What brand and series of caps did you use? That whistling could be due to a cap out of spec.
3. Use a tube like the center of a roll of towels to localize the source of the whistling.
4. A picture is worth a thousand words. Note the link in my signature for tips on getting good ones.
5. On either end of the ZXCVBNM<>? row of keys are 'Shift' keys. Learn to use them, please.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. -
these are the three caps that i used
CAP 1
http://search.digikey.com/scripts/Dk...ds=493-1525-ND
CAP 2
http://search.digikey.com/scripts/Dk...words=P5138-ND
CAP 3
http://search.digikey.com/scripts/Dk...ords=P11685-ND
So are you saying the whisteling would be coming from the specific cap?
Does cap series matter. If so in what wayComment
Yes, capacitor series does matter.
For example, If you replace a low ESR capacitor with a general purpose non-low-ESR capacitor you can get problems. Or it may work, but only last 3 months.
Please write a list of what capacitors you removed, what brand and series they are (or what markings were on them)"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
16v 680uf LXV (M)105c 2(2) 7c
CAP 2
16v 100uf SMG (M)85c
CAP 3
450v 270uf CE 85c LS (M) nichicon
the large cap was the only one that was labeled with a brand name so i assume the rest were of the same brandComment
The HE's are very good as is the ED series.
The M's are only 85°F caps and I don't like their (lack of) specs for SMPS use. I would suggest Panasonic FM's in 120uF@16v or 100uF@25v or the Nichicon HE's in 100uF@25v.
I would look to the CAP 2 near the big cap as a probable cause of the squealing. It's very likely not low enough in ESR for the switcher.
Toast
"the large cap was the only one that was labeled with a brand name so i assume the rest were of the same brand"
FYI: The others had a little shield emblem which is United Chemi-con.Last edited by Toasty; 11-21-2010, 12:13 AM.veritas odium paritComment
interesting....the little ones were the ones causing the problem in the first place. ill get some new (better) ones on order and let ya know how it goes. when i put the paper towel roll over the board to see where the squeeling was coming from it seemed to be coming from the big cap. but that little one is pretty close to it so who knowsComment
This specification for the Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P51s + ThinkPad Stack Mobile Projector boardview and P51s + ThinkPad Stack Mobile Projector schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....09-06-2024, 06:11 AM
by narfhi all,
first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
what i've found so far:
- the PSU does its job and supplies 12V to the mainboard via the connector.
- shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
- not far away, there's the first cap with a resistance of 0.7 ohms.... -
by budwichGot this projector which has a problem with a lack of blue. Menu text is very yellow... expecting white. If I input a signal from a test disc via hdmi, a red screen image shows a uniform red as expect. Green similar while the blue does show but with non-uniformity. Looked at the in-polarizers. They are all good and clean. Running the projector to expose the light area in the prism block, shows each color well represented, all looking about the same intensity from the naked eye. Looking at the prism block itself and sending a light source back into the "out port", the individual...
by giyaHI EVERYBODY HELP ME.
FIRMWARE/BIOS PROJECTOR SONY VPL-DX142 CODE BOARD 4H.1NT01.A03
ATTACHMENTS BIOS OLD...07-11-2025, 12:41 AM -
by MufasaI have a Kodak Lumia 150 projector and the power switch fell off the circuit board when the button was pushed. The power switch itself is missing and I can't figure out where to find the replacement.
Anyone familiar with where to find this type of button and how to source it?... - Loading...
