Philips 42 Plasma 7 blinks 42PF7220A /37
  • DakotaKid
    • Nov 2010
    • 165
    Philips 42PF7220A/37 42" Plasma, Chassis BP2.3U.AA, mfg 4/06
    This TV is flashing the 7 red led error message on the front panel indicating a power supply problem I believe. I opened it up expecting to find bulging 3300 uf caps in the power supply circuit but they appear ok, at least not visibly bulging on their tops. I have a couple of new 3300 uf 16V caps that I could go ahead and put in but I would like to do the proper troubleshooting first unless someone here advises me differently. I'm just not sure where I should start as far as checking voltages or what values I should be looking for.
    I have no fear in tackling this one. I have a DMM and can use it, I have a decent amount of soldering experience, I am pretty good with electronics, and I am overall very handy. I just don't know a lot about these TV's other than the easy visibly bad cap repairs. This is my 3rd plasma to resurrect with the first two being successful. I'd like to get this one done because I've already acquired my NEXT project! It's a 55" Mitsubishi rear projection with what I believe is bad power supply caps...but it has to wait for another day.
    Any help on this Philips would be greatly appreciated. Should I go ahead and replace the two caps in case they are bad, just not visibly bulging?
    Thanks in advance.
    DaKid
  • PlainBill
    • Feb 2009
    • 7034
    Re: Philips 42 Plasma 7 blinks 42PF7220A /37
    Thanks in advance.
    DaKid
    The service manual is available at www.elektrotanya.com. If the set has the latest firmware, 7 blinks indicates a problem with the 8.6 volt supply. If the two 330 uF caps are Samwah's I'd replace them.
    PlainBill
    • DakotaKid
      • Nov 2010
      • 165
      Samwha's they are! I will replace them when I get a chance and report back with results. Meanwhile, thanks for the link to the manual, I'll have a look at that too.
      DK
      • PlainBill
        • Feb 2009
        • 7034
        DK
        While you're there you should also look for the service manual for the plasma panel. I believe that set uses a S42AX-XD02 or S42AX-YD01
        PlainBill
        • DakotaKid
          • Nov 2010
          • 165
          Replaced the two 3300 uf caps on the main board, no change. A few more details about what I observe now (and same as before)...the two green leds near where the input power leads plug into the board light up for about 5 seconds after two clicks are heard. After 5 seconds or so they go off and the front led starts flashing the 7 red flashes and repeats this. A small circuit card attached to the main board has a green led that flashes 3 times and repeats this over and over. Down on the lower board, the one that connects to all of the audio / video outputs also has two micro leds, the first comes on green when the other two do, the other flashes for the same 5 seconds until the main power shuts down.
          DK
          • PlainBill
            • Feb 2009
            • 7034
            DK
            There are several possibilities. It's been about a year since I tackled one of these. It had a back-level firmware and the bulged caps. It would flash an error 11. I replaced the caps and updated the firmware. This COULD be reporting the wrong error. Or there could be a problem with the 8.6 V supply, or the load on the supply.
            One of the easiest tests is to check the output voltages of the power supply. Start with the outputs to the SSB. The 8.6 volt supply is on pin 3 of the 11 pin connector.
            PlainBill
            • DakotaKid
              • Nov 2010
              • 165
              I removed the plugs from the X and Y boards and the TV no longer shut off. I plugged the X board in and it didn't shut off. I plugged the Y board in and it did exactly what it was doing before, power on for a few seconds, shut off, repeating 7 red blinks on the front indicator. So, I presume this means it is either the Y board or the circuit in the power supply board that supplies the Y board. I will be checking the voltages and will report back. I downloaded the manual that was linked but I could only get it to come up in Spanish and me no hablo espanol. Thanks for any help and advice.
              • DakotaKid
                • Nov 2010
                • 165
                Update: I checked the voltage test points on the main board and found the following. Any time that the Y sus board is plugged in the system exhibits the shutdown and 7 red blinks I mentioned before. The riser card on the power board blinks 3 tmes in succession repeatedly and the other LED's go off after about 8 seconds. Most of the voltage points go to 0. When I unplug the Y sus board then everything appears to be normal other than no picture. There is no error code, no 3 blinking green led's. The Ve, Va, Vs, Vscan, Vset, 12V, 5V, 3.3V all measure out within a reasonable measure of the voltages printed on the sticker in the tv case.
                I don't know much about these Y sus boards but this leads me to conclude that the Y board is the most likely culprit, probably a shorted component. Upon examination, all caps on that board look fine and there is no visible burned marks or charring of any type. I am looking for advice on what steps to take next to validate my assumption or continue the troubleshooting.
                Thanks.
                DK
                • PlainBill
                  • Feb 2009
                  • 7034
                  Thanks.
                  DK
                  If the numbers on the Y-Sustain and Y buffers are LJ92-01200A, LJ92-01202A and LJ92-01203A, you have a common problem. I'd suggest reading http://blog.coppelltvrepair.com/ for a discussion of the problems and the (expensive) solution.
                  PlainBill
                  • DakotaKid
                    • Nov 2010
                    • 165
                    Ouch! I don't like what I read, is there a second opinion that is more favorable? LOL, just kidding. Of course mine are the 120x boards. That pretty much nails my situation so it appears that I am looking at repairing all three boards at a minimum if I want to get this thing running again. I have long been telling people not to pay any more than scrap value for used plasmas on CL because they have either been repaired or will need to be repaired. Now I understand the supporting evidence underlying what I knew intuitively. Although I can now tell people that it will likely need repaired again EVEN IF it has already been repaired. The two 3300uF bad caps replacement isn't necessarily the end-all fix even if it gets the tv up and running again short term.
                    I'd be willing to do the repairs if I knew which IC's to replace but maybe it's time to just sell it off to the scavengers on CL in its current state. Has anyone ever come across more info on the details of the board repairs so I have a better understanding of the extent of what I am contemplating here?
                    PlainBill, thanks for the info and link, at least that Coppell blog provides a seemingly fair and objective viewpoint from an apparent expert without resorting to scare tactics.
                    DaKid
                    • PlainBill
                      • Feb 2009
                      • 7034
                      DaKid
                      Coppell TV's blog indicates that EVERY buffer chip should be replaced. His theory is the silicon sealant around the leads breaks down, triggering the failure. These are SN755867 / SN755870 and cost $13 each.
                      On the Y-sustain there are a set of IXTA36N30P transistors under a heat sink. It is possible to isolate the one which has failed and replace only that one. They run $7 each. The problem is these are the TO-263 package, so it required pretty good rework equipment to remove them.
                      PlainBill
                      • DakotaKid
                        • Nov 2010
                        • 165
                        How would I best go about determining which of the 36N30P transistors is bad?
                        Thanks for all of your advice and help.
                        DK
                        PlainBill
                        • PlainBill
                          • Feb 2009
                          • 7034
                          DK
                          That was covered in another section of the Coppell TV blog.
                          It's a lot easier if you pull the heat sink over the transistors.
                          PlainBill
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            I don't know what this board looks like or how easy it is to access the transistors, but the datasheet at
                            shows them as 3 pin. So with power off and TV unplugged, measure "in circuit" the ohms between S-D, S-G, and G-D. Any reading less than 30 ohms suggests a possible short.
                            --- begin sig file ---
                            --- end sig file ---
                            • DakotaKid
                              • Nov 2010
                              • 165
                              Makes perfect sense, I will test them out and see what I find.
                              Thanks.
                              • jm1234
                                Panasonic plasma TX-P42ST50 - 6 blinks
                                by jm1234
                                anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                I checked that board for any obvious faults...
                                05-22-2024, 06:59 AM
                              • Alicat
                                Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                by Alicat
                                Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                Model number is TH-50PZ85U
                                Power comes on and the red power light stays on solid.
                                Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                I also hear a few clicks.
                                I also think my parents said there was a thunderstorm and the TV failed after that.
                                Section 6 in the service manual talks about power and no screen,...
                                10-30-2024, 10:09 AM
                              • M80
                                Samsung PN51E550D1FXZA plasma no power up 2 blinks
                                by M80
                                Samsung model # PN51E550D1FXZA plasma TV after a lightning hit (LAN cable was connected to TV). Standby LED on ok, but when pressing the power button, getting 2 blinks on the red LED, the screen flashes white for a second, and then cycles through this loop routine.
                                ALL voltages Vs, Ve, Vsc, Va check ok at SMPS output pins and at Main Board connector and X/Y drive board test points.
                                Noticed the Logic Board LED lights up green for a couple of seconds, hums lightly, then goes off during this cycling.
                                I've reseated ALL connectors and none of the boards have any burned traces or...
                                08-11-2022, 04:34 PM
                              • nick31
                                Panasonic Plasma ST50 TC-P55ST50 P55ST50 8 blinks
                                by nick31
                                My Oct 2012 panny plasma quit working yesterday.
                                It was on when it happened. It let out a bit of burned plastic/circuit board smell. I was not able to find any burned parts though.
                                Now it produces 8 blinks. According to the repair manual, that points to SS/SS2 board(s).
                                I completed the steps in the guide: unplugged SS33, the TV turned on with a black screen, no blinking codes. Then I checked the continuity between pins 1 and 2 of the connectors SS52, SS54-SS57. The continuity is ok in all of them. Guide suggests to replace SS/SS2 boards so I placed an order...
                                04-21-2021, 09:56 AM
                              • Biruslapio
                                Panasonic P58V11B 8 and 12 blinks error "fix"
                                by Biruslapio
                                Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                04-13-2021, 07:13 AM
