Hitachi 57F710E Power Issue
+ More Options
Posts
  • navagator
    • Aug 2018
    • 23
    I have a Hitachi 57F710E Rear Projection TV that was working great until 3 or 4 days ago. I came in and tried to turn it on and it was just dead. So, I unplugged it and plugged it back in. Nothing, not even the slight click that it makes when you plug it in. So, I removed the power supply board (It's a vertically mounted board, I believe model HA01312) and inspected it visually for bulged caps or burnt or overheated components, anything that didn't look right and couldn't find anything.
    I noticed on the bottom of the board there was a row of solder joints with voltages printed next to them(10.5v, Gnd, Gnd, 5.6v, 5.6v, Gnd, 16.5v (not used), Audio Gnd, Audio), which are coming from the large transformer on top. I checked all of these voltages and they're all reading between 12.5 - 12.7 volts AC. I assume this isn't right.
    I would really appreciate any help anyone could give me in fixing this issue. It's an old TV but it still has a great picture and I would prefer to fix it if I can.
  • R_J
    • 9583
    Re: Hitachi 57F710E Power Issue
    Check if F904 fuse resistor (2.2Ω/5w) is open. If it is open it is usually because the relay contacts (S901) that normally short it out are bad, You can short the resistor with a wire to test the rest of the circuit but the resistor and the relay should be replaced
    • navagator
      • Aug 2018
      • 23
      It's closed, I have continuity between the 2 legs of the fuse.
      • R_J
        • 9583
        Do you here any of the relays click when you apply power? there are a few pico fuses to check on the board as well like E940, E941 and others that look like it.
        You should have standby voltage across C940, likely around 6vdc, if not check for 160vdc across [- +] of D901 bridge rectifier. If no 160vdc check for 125vAC across K002 and K003 jumper wires, this is the main A/C input
        • navagator
          • Aug 2018
          • 23
          No, I don'the hear any clicks.
          • R_J
            • 9583
            Did you check for the standby voltage? did you check ALL the fuses?
            • navagator
              • Aug 2018
              • 23
              There's around 12.8vac at C940, around 2.8vDC at D901, 121.5vac between k002 and k003. I went back to check D901 again because I didn't think I got a very good measurement before and unfortunately I hit a solder joint accidentally I shouldn't have and blew one of the glass fuses, F901, so I guess I'll have to order one of those before I can go any further. Also, I haven't checked any of the other fuses you mentioned yet.
              • R_J
                • 9583
                The voltage on C940 is DC NOT AC
                If these voltages are correct then D901 must be bad or F902 is open because you can not have 121.5VAC going into the bridge rectifier and only 2.8VDC coming out.
                • navagator
                  • Aug 2018
                  • 23
                  I'm sorry I was checking D940 instead of C940. I'll check C940 as soon as I can get a fuse.
                  Thank you for help.
                  • navagator
                    • Aug 2018
                    • 23
                    Could you tell me whether this is a fast or slow blow fuse? I can't see anything on the fuse to indicate this.
                    • R_J
                      • 9583
                      Found it
                      FUSE F901 51MS 080 L-U I believe it is a Medium Time-Lag Type fuse, 8 amp 250v
                      • navagator
                        • Aug 2018
                        • 23
                        Okay, medium time lag. The blown fuse was a 8 amp 125v, but it didn't have a F, M, or T marking on it.
                        • R_J
                          • 9583
                          I should have said 125v, don't know why I typed 250v
                          • navagator
                            • Aug 2018
                            • 23
                            I found them on Amazon, I'll get them ordered. Thank you.
                            • navagator
                              • Aug 2018
                              • 23
                              The fuses came today, I put one in and plugged it in, but unfortunately as soon as I plugged it in the fuse blew.
                              • R_J
                                • 9583
                                What solder joints did you short on the power supply? Check if D901 is shorted, I suspect it is shorted
                                • navagator
                                  • Aug 2018
                                  • 23
                                  I was looking at the meter when it happened, so I not completely sure. But I was testing the + and - of D901, the bridge rectifier.
                                  • navagator
                                    • Aug 2018
                                    • 23
                                    Ok, I did test the rectifier but I did so while it was still in line, I couldn't get downstairs at the time where my solsering iron is. I can remove it though later to test it if I need to.
                                    I touched the + lead of my meter to the - leg of the rect. and the - lead of my meter to one of the AC legs of the rect. I got a reading of 482. Then I reversed this process and got a reading of 0.
                                    Then I touched the + lead of my meter to the other AC leg of the rect. and the - lead of my meter to the + leg of the rect. And got a reading of 0. Then I reversed that process and got a reading of 0 also.
                                    I hope I did that correctly, if so, that doesn't sound right.
                                    • R_J
                                      • 9583
                                      Are you using diode test on your meter? What is 0? 0Ω = a short (same as probes being shorted together)
                                      A bridge rectifier is just 4 diodes in one package, 2 diodes are shorted.
                                      • navagator
                                        • Aug 2018
                                        • 23
                                        I'm using the diode test on my meter. It actually reads .482v and .OL and the other 2 readings are both 0v.
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • justice171
                                          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                          by justice171
                                          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                          1. Verified that all critical voltages are present:
                                            • 3.3V and 5V are always present if DC is plugged.
                                            • 1.8V on the BIOS chip is present.
                                          2. Checked the power button functionality:
                                            • When pressed, the voltage drops to 0V, indicating the button is functional.
                                          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                            • Confirmed connectivity is intact, ruling out issues
                                          11-26-2024, 12:39 AM
                                        • claws77
                                          lenovo flex 5 14itl05 power sequence issue
                                          by claws77
                                          hi guys, my motherboard will not start no matter what
                                          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                          but rest nothing happens no sign of life.
                                          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                          i have no knowledge of motherboards ....
                                          10-20-2024, 02:48 PM
                                        • yaya3gmax
                                          Laptop Power Issue – Works on Battery, Fails on Adapter Load
                                          by yaya3gmax
                                          Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                                          Symptoms:
                                          • Laptop works normally on a pre-charged battery.
                                          • Battery does not charge when adapter is connected.
                                          • Without battery:
                                            • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                                            • Speakers “pop” when power cut occurs indicating harsh sutdown.
                                            • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                                          08-21-2025, 07:16 AM
