Re: Samsung ue55mu6202k bn94-12778s Not turning on (dump help ?)
I think we're done here: tried to apply 3.3v to pin 8 of the 24C512 IC to see if anything might cause the 3.3v regulator to shut down and the smaller die of the CPU began to heat up. I'm not sure this is normal because it doesn't have a heatsink on, but I doubt it'd get that hot...
Oops.....Ok, big fail on my sideI was still fixated on the idea that I should try replacing the original 25Q40 SPI chip with something else for testing, like I tried with the Q64, so when I saw C512 on there, it didn't occur to me to read more carefully, so I thought I should now seek out a Q512 IC to try in place of the 25Q40, which is a stupid thing to try because this is the EEPROM we're talking about, which is not only a different physical form factor but also has a different prefix - 24, instead of 25....so here I was, trying to fit this thing on the pads of the SPI IC, only to figure out it's too small and would NEVER be compatible anyway.
Good thing I stopped in time and read again more carefully, putting 2 and 2 together. I assume we're talking about this guy in the picture thenPulled it off and saved the contents, just in case it's of any use. Tried out what lotas provided but it still doesn't work. I don't know for sure, but it appears to have changed the blink pattern (or not, can't remember for sure): LED comes on and stays solid for a few seconds, then blinks twice rapidly, pauses for another second then repeats 4 more times (so 5 sets of 2 flashes before becoming solid again and repeating).
There's another thing I noticed: this EEPROM IC is not getting consistent power. I measured pin 8 and briefly got 3.3v at startup, which then went away and didn't return. Even stranger, NOW the blink pattern also changed: it no longer did the consistent pattern above, but seemed to be off most of the time. I thought it had something to do with my soldering, seeing how touching my meter probe to the pin caused a change in behavior, but that's not it. The resistance to GND of that pin reads 1kOhm. Touching the meter's probe to that pin causes this, as it keeps going otherwise...Last edited by Dannyx; 11-15-2023, 02:19 AM.Leave a comment:
Will do as soon as I have one. I noticed the first part is blank in this one.Leave a comment:
25Q40 - supports Quad, 24L40 - no, try rewriting eeprom 24C512.Attached FilesLeave a comment:
I tried it again today with a different chip but same story, even worse actually. I tried a 25L40 (as opposed to Q40) and apparently it doesn't have the 3 registers (only 1 column shows up in NeoProgrammer, so I can't set 42, only 88). I tried it out anyway just to see what happens and this time I didn't even get the standby LED to come on, so that clearly didn't work. It also tells me there is some communication present, even in this half-dead state, which enables the stand-by state, otherwise the different chip wouldn't make a difference, but it does, so most likely the problem is the flash.
I then tried a 25Q64 chip, since it has the two registers I can set and the LED comes on, but we're back to the original state (blinking twice), so the problem's not here sadly...
Another thing I tried, going back to my very first days of learning to fix TVs, I shorted the MISO and MOSI lines together as I plug in the power. The LED comes on solid then goes off after a few seconds and doesn't blink anymore after that until I release the pins, at which point it just goes back to blinking....thought I'd just give it a shot to see what happens, since the board's dead anyway...Last edited by Dannyx; 11-13-2023, 03:16 AM.Leave a comment:
ch341 will read and write all spi if the PIN 28 disconnect from circuit and go direct to 3.3V
otherwise will kill the chipsLeave a comment:
Good to know they still work, I must have gotten stuck with a bad one.Leave a comment:
Wonder if you have a bad ch341, the one I recently had to return must have been bad, it read 2 chips, but could not read another after that, not even the first 2 that it read, all readings came back all ff.Leave a comment:
I haven’t tried this one, I don’t know.Leave a comment:
Wonder if I could use a larger one, say a 64 IC, since I don't have a 40 one right now...Leave a comment:
Try it, but it seems to me that this is not the case.Leave a comment:
I think I did that the second time around. The order looks like this: put chip into programmer>detect it (I choose the closest one)>unlock>erase>blank check>open bin file>write bin file>open "edit SREG" >check the 4 checkboxes, uncheck the last one>hit write. Should I bother to try with a new 25Q40 ?Leave a comment:
Status register in SR 3 should be 00, that is, all checkboxes are unchecked. Should be 88.42.00.
Also remove the checkboxes for "Locked" on SR2, SR3.Last edited by lotas; 11-10-2023, 04:35 AM.Leave a comment:
Ok, I tried it several more times but no success.
I had some issues with ASProgrammer which wouldn't let me tick the QE box for some reason (first screenshot). I then tried NeoProgrammer which did - think there's some issue with the CH341...anyway. I'm sure I did everything right this time: removed chip, unprotected it, erased it, opened dump file, program, checked the 4 checkboxes you indicated and uncheck the one on the far right and hit "write", so I think the CPU's dead or no longer soldered properly. The jumper wire between the TRDY pads is still in place BTW, just to rule out the possibility of a bad panel.
There's another thing I noticed which makes me think the SPI chip is failing to communicate with whatever it's supposed to talk to (most likely the CPU): while I was trying out AsProgrammer, since it wouldn't let me tick the QE box, I just ignored that step entirely and installed the chip without setting any of the 4 options, just to see what happens - of course I got the same 2 flashes and nothing else, but from what I read in other posts where others tried it without setting 88 and 42, the TV just dumped FFs on top of the header there at startup, essentially corrupting the dump again. Mine doesn't do this - the header stays intact when I read it again. What's more, I noticed the 4 options ticked themselves when I pulled the chip off the board and read it a second time (second screenshot). I didn't touch anything, except hit "read". The TV DID something to it though, because I used HxD to compare the BIN on my PC with what the SPI chip had on it after powering on the TV and there are some changes deep down in the file - some FFs in the original now had other random values. Attached the BIN that resulted after trying the dump from post #20, should it be of any use...Leave a comment:
If there were only FF in the dump header, then the TV would not even have a standby mode and the red LED would not light up either.Leave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by CesarTurboPCCould you help me... I have a Samsung UN55MU6103F with the following problem, dead TV, I disconnect the main power supply and the leds light up. I know it is a problem in the firmware in the IC SPI Flash W25Q40CL (IC1604)
The model of my TV is
UN55MU6103F
Power supply BN44-00807A
Main Board BN41-02568B
Could you help me to repair the dump please. Thank you.
I leave my backup of the dump and a little extra, it is the schematic of the power source, it can be useful to someone. Regards... -
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
