SONY Bravia KLV-32s200a MultiSystem Problem
  • mamanaia
    • Nov 2010
    • 6
    I have the above type of T.V. that was purchased in Thailand and used there for 3 years. Since the manual and information I saw said it was multi-system compatible, I shipped it to Costa Rica where I have tried to use it. I get a picture, but I do not get any sound. I have searched the menus, but I can't find anything suggesting I need to change settings for it to work here.
    The VHF/UHF connector on the T.V. is the Asian style connector, but in Costa Rica, they use North American coaxial cable. I purchased a simple cable plug adapter at radio shack.
    Do I need some other cable adapter that connects the coaxial to the T.V. or is there a setting change I need to make on the T.V.?
    Thanks in advance for any advice.
  • switch998
    • Oct 2010
    • 13
    Re: SONY Bravia KLV-32s200a MultiSystem Problem
    test your tv out with a DVD or VHS player, if there's still no sound then the only think I can think of is a cold solder that is now causing problems due to an altitude change.
    • mamanaia
      • Nov 2010
      • 6
      I have been using the T.V. with a DVD player since it arrived in Costa Rica without any sound problems, so that does not appear to be the issue.
      I tried to set it up again just after posting and I notice I get sound on 2 channels, but not the other 60 channels or so.
      • Tvbob
        tvbob
        • 204
        Try doing an auto scan, are you getting analog or digital channels. does it have sap settings
        • mamanaia
          • Nov 2010
          • 6
          I did the auto scan. It looked for VHF Low, High and UHF channels. Not sure what you mean by digital beyond that. Also not sure what a sap setting is and where I might find that.
          • PlainBill
            • Feb 2009
            • 7034
            SAP = Secondary Audio Program. Check the sound menus for the settings. The TV may be set to use the audio on the secondary audio channel.
            PlainBill
            • mamanaia
              • Nov 2010
              • 6
              Unless I'm missing it somewhere, there is no SAP option. I even tried to reset manufacturer settings. I get sound on 3 channels and no sound on over 60 channels.
              • PlainBill
                • Feb 2009
                • 7034
                Well, I just went to Sony's support page for that model and downloaded the manual. It definitely has SAP capability, unfortunately I can't read much of the manual.
                PlainBill
                • mamanaia
                  • Nov 2010
                  • 6
                  I also went to the support page, but the model they show has manuals for Latin America, U.S. and Canada. I bought the T.V. in Thailand 3 years ago. The Thai support site no longer has the model listed for support.
                  • mamanaia
                    • Nov 2010
                    • 6
                    Okay. I've finally found my manual (misplaced after the move). I looked at it, and now I've figured out that the sound problem may be due to a weak signal from the coaxial cable. That is why I don't get an SAP option right now. It appears that a weak signal only allows mono output and doesn't give me choices.
                    My landlady is planning to replace the cable wire, so I will report back if this solves the problem.
                    Thanks for the advice.
                    • PopsCaps
                      Sony Bravia KDL-40V2500 that will not power on
                      by PopsCaps
                      I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                      I do not hear any sound and I cannot see any backlight.
                      I have tried disconnecting every cable on each board one at a time to see if anything changes.
                      The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                      My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                      03-25-2025, 11:23 AM
                    • justin35
                      Sony bravia kdl-43w755c - boot loop
                      by justin35
                      i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                      from what i read online it looks to be an emmc issue…
                      i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                      i took out the board and say an samsung 16gb emmc
                      i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                      i could try to put one instead of the 16gb one, but will it work?
                      where do i get the software from?
                      any help will be much appreciated!...
                      03-06-2024, 12:26 PM
                      Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                      Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                      10-16-2024, 05:15 AM
                    • Spc.
                      Sony Bravia KD43XF7596BAEP - Android no picture
                      by Spc.
                      Greetings everyone.
                      I also have Sony Bravia, model:
                      Sony Bravia KD43XF7596BAEP - Android.
                      What happend is that image dissapeared while we were watching tv.
                      Diagnostics:
                      1. TV turns on, no errors
                      2. Backlight turs on, no errors
                      3. Power indicator turns on, white color, no errors
                      4. Menu works on android, you can hear sound while switching channels
                      5. Volume up and down works via TV remote and via buttons
                      6. Tunner works, HEVC / MPEG-4 decoder works
                      7. I get audio from channels
                      8. No picture is present,...
                      05-19-2022, 04:28 AM
                    • KYBOSH
                      Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                      by KYBOSH
                      Previous owner said TV just went blank one day.
                      They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                      Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                      The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                      There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                      I just downloaded the Sony KD-75X7800F Service Manual and...
                      11-19-2024, 10:12 AM
