Philips 75PFL5704/F7 A Video Issue
  • Nicktronic
    • Mar 2023
    • 247
    Hey everybody, got a strange one here.
    The TV will display the Home Screen, Menus, Netflix Home Screen, YouTube home screen with preview tiles, etc, without issue. As soon as I try to play video (streaming or from any of the HDMI inputs), all I get is audio and and blank screen. It's like the video is not being processed. So I ordered a replacement main board. I can now play video from streaming sources but the video from HDMI sources is all green (kinda like photo negatives but all green) and the audio does not work. Is it possible the main board I ordered is also failing?? I can't see the T-Con being the problem, as it works showing menus, tiles and streaming video. I have no idea where to go from here. Hope somebody has some pointers...
    Pictures attached.
  • EazyBone
    • Jun 2023
    • 1347
    • United states
    Re: Philips 75PFL5704/F7 A Video Issue
    What happens when you stick the old main board back in? Problem back? There's always a possibility main board ordered is bad. They come from broken used tvs generally.
    • Nicktronic
      • Mar 2023
      • 247
      Yeah, exactly, the same symptoms come back with the old board.
      Of note, pretty loud buzz coming from both the main board (original) and the T-Con board. When i put the new main board in, no buzz, but the T-Con continues to buzz. Thoughts?
      • EazyBone
        • Jun 2023
        • 1347
        • United states
        So you put original board back in and green goes away is what I meant to ask?
        So with new board screen is green but everything works normal.
        With old board screen is not green but streaming pauses.
        I mean sounds like you got a bad board from whomever. I don't actually have any info on this problem and can't be much help but If original board is fine with color and replacement isn't I'd assume replacement is bad. Maybe you can use search functions to find green picture or something
        • Nicktronic
          • Mar 2023
          • 247
          New board - Good menus, static images, etc. Green screen during HDMI video AND no audio. Streaming video AND audio work find.
          Old board - Good menus, static images, etc. No video playback with HDMI AND streaming (black screen), but audio is good.
          • EazyBone
            • Jun 2023
            • 1347
            • United states
            Odd. You tried different HDMI cord I assume?
            I mean if you can stream video with audio then I can't see how a Tcon would be your issue. It sounds like something is wrong again with the main board or the cord going to it. If consider hooking up that device to another TV to test it also just to see it's not the devices end. But just by logic it would indicate a bad main board if everything else is working fine. Usually the pros don't comment on these cheap TVs lol but id try new cord/other tv first to rule all that out.
            • diif
              • Feb 2014
              • 6978
              • England
              I suspect the BGA under the main processor is at fault on the mainboard.
              • Nicktronic
                • Mar 2023
                • 247
                I agree, can't see the T-Con being the issue at all. Tried a different input device and this time got good video on all three HDMI ports but but the green screen would flicker in and out periodically. I guess I gotta look at the ribbon cable between the Main Board and the T-Con, and then possibly the new main board being faulty.
                As diff mentioned, if BGA is the problem, I could do a rough test on the old board by cooking it for 10 minutes in the oven just to see.... (I know it's a hack repair, but don't care so much on the old board!)
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  You want it to be around 5-6 minutes in total and ensure it's hot enough 218c/424f to melt the solder. Remove the heatsink first and ideally you want to use some flux.
                  • Nicktronic
                    • Mar 2023
                    • 247
                    So, I did what you said and no change in operation unfortunately. Is 6 minutes @ 425F enough to melt the solder though? I did use flux and removed the heatsink. This is blowing my mind that both boards operate "kinda" the same way. Possible both new and old main board processors are bad....
                      HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                      This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                      09-12-2024, 02:00 PM
                    • ovrax
                      Philips 55PUS6804/12 turn on & off (probably backlight issue)
                      by ovrax
                      First of all, please excuse me as I'm quite new to this field.
                      I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                      I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                      The Ambilight works perfectly and stays on.
                      No sounds.
                      Thanks in advance.
                      08-25-2024, 04:33 AM
                    • razorhead
                      HP Elitedesk 800 G5 Desktop mini video issue
                      by razorhead
                      Hello I have a HP elitedesk 800 G5 Desktop mini with a boot issue. I have the lights and fan come on (normal speed), There is no video. I was working fine, posting with initial HP logo before and then it just stopped. Now it just turns on with power LED, fan on, No video and no response to keystrokes. The LEDs on the keyboard also stay off.
                      I have attached the main and EC bios dumps here. I have also tried to clean ME and reflashed again, but I am unsure if I did it correctly or not. Attached are the pre-cleaned Bios Dumps. Please help fix this. Thank you very much,
                      Model HP...
                      09-23-2023, 08:33 AM
                    • charlesdutcher
                      No picture issue in Philips Chassis FTL2.1
                      by charlesdutcher
                      My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
                      Is there someone having any symptom like this? How to fix it?
                      Thanks in advance!​
                      08-06-2024, 09:55 PM
                    • celiabrown
                      Issue with Plasma Philips 37inch chassis FTL2.1
                      by celiabrown
                      Hello guys,
                      My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                      Can someone has any symptom like this ?
                      Thanks​
                      05-09-2024, 10:56 PM
