Samsung SyncMaster T24B350
  • jason123
    • Oct 2015
    • 1136
    Hello there,
    I had this TV for years plugged in connected to an old xBox. Went to turn it on today, and I noticed standby light is off, and not turning on.
    Opened it to find the Corner Cap (for 5V standby I believe) is bulging and replaced it. Still no standby light. won't turn on
    Measured voltages going to the main board, and with the connected to the main board in place, the 5V, PS_On, and 13 V pins were jumping all over the place. When I disconnect the cable to main board, the 5V reads 5.2V, the 13 V, reads 11.8V, and the PS_ON is 3.12 V and the backlight comes on.
    I'm thinking main board is out to lunch but I figured I'd post this and see if anyone has experience with these as to common components that may go bad??
    • 12328
    • U.S.
    Re: Samsung SyncMaster T24B350
    Maybe try unhook lvds cable at mainboard and retest those voltages, just to make sure it isn't the panel making them unstable.
    • jason123
      • Oct 2015
      • 1136
      Thank you. Done. No effect on these voltages. With LVDS disconnected, voltages all over the place still
        • 12328
        • U.S.
        Maybe a bad voltage regulator on mainboard?
        • Storyteller12
          • Jun 2020
          • 625
          I’ve seen a few like this were a bad diode on mainboard caused voltages to fluctuate. A lot of times it’s next to one of those 8 pin ic’s and the diode and ic will be bad.
          • jason123
            • Oct 2015
            • 1136
            So I took the main board and provided external +5 and +12 V and GND
            Current draw was in the 200 mA range on the 12 V, and less than 50 mA on the +5.
            Could it be the power board that's unable to provide enough juice?? I did replace all the caps on that board, but I'm not sure if it's some sense resistor or something not allowing it to provide all the muscle it needs?
            • jason123
              • Oct 2015
              • 1136
              Originally posted by Storyteller12
              I've seen a few like this were a bad diode on mainboard caused voltages to fluctuate. A lot of times it's next to one of those 8 pin ic's and the diode and ic will be bad.
              Hi, after post #6, do you still think this would be the case? Thank you
              • lotas
                • Jan 2016
                • 4848
                • Russia
                If the power supply is unstable with large pulsations, the firmware in the spi flash could suffer.
                • jason123
                  • Oct 2015
                  • 1136
                  Another experiment:
                  with everything connected, I forced the Power Supply to turn on by throwing a resistor between 5A (Standby - stable at 5.2 V) and PS_ON on the main board.
                  This did result in the Backlight being on, 5B pin @ 5.18 V, 13V Pin @11.80V all stable. No display on the screen however (Just bright backlight)
                  I also noticed the large cap voltage is still 157 VDC (was 161VDC before the forced PS_ON pulled high externally.
                  Should the large cap voltage go high to ~300 V or So?
                  • lotas
                    • Jan 2016
                    • 4848
                    • Russia
                    There is no PFC (Power Factor Correction) in the power supply, the panel is small and the backlight is LED. If the backlight turns on without the motherboard and lights up without failure, then we can assume that the power supply is corrected.
                    • jason123
                      • Oct 2015
                      • 1136
                      I have a replacement main board on order. Fairly expensive board for such old TV, but I'd love to get it fixed - anyone has experience with this board?
                        • 12328
                        • U.S.
                        Probably the usual, poor solder ball connection of the bga after many many power thermal cycles, also the boards tend to warp over the years, making it still harder for those solderballs to keep connected.
                        • jason123
                          • Oct 2015
                          • 1136
                          Did a reflow on the processor - no luck. Touch up many solder joints, still. I noticed that the Flash chip (with sticker) is not getting power on pin 8. From datasheet, VCC is supposed to be in the ~3V range and I'm getting 0.8 V
                          Lifted the pin (to see if that chip is shorted) but pad was still 0.8V. Anyone with a schematic for this board? Thank you
                          • lotas
                            • Jan 2016
                            • 4848
                            • Russia
                            Your power supply should be suitable not for 8 pin, but for 2 pin.
                            • jason123
                              • Oct 2015
                              • 1136
                              You're correct - Pin 2 of this IC is reading 0.8 V
                              This pin is tied to Pin 1 of the same IC. And that's connected to Pin 8 of the adjacent IC (ATMLH208) - I can't find a datasheet for that IC!
                              • lotas
                                • Jan 2016
                                • 4848
                                • Russia
                                This is an EEPROM, the full name requires a second line.
                                • jason123
                                  • Oct 2015
                                  • 1136
                                  ATMLH208
                                  2GB 1
                                  1H1109
                                  Another note: This morning when I powered up the board (applying +5V and 11.8 V and GND), the voltage at the VCC pins were 0.448 V... then when the board warmed up, it went up to 0.823 V
                                  I momentarily applied 3.3 V (from a switcher on the board) to the VCC pins of these Flash / mem.. and the voltage held (meaning, it's not really low impedance on these nodes, simply the source is not able to drive 3.3v?)
                                    • 12328
                                    • U.S.
                                    Wonder if there's a bad capacitor in that area.
                                    • lotas
                                      • Jan 2016
                                      • 4848
                                      • Russia
                                      ATMLH208 2GB 1 - AT24C1024B
                                      Here is a video of powering your board:
                                      https://www.youtube.com/watch?v=Ly1UURZ2ml4
                                      • jason123
                                        • Oct 2015
                                        • 1136
                                        Thanks.. I can't understand Hindi, but I think my board checks out except for the Memory Chips VCC.
                                        I found this video of a board with very similar problem to mine. But I'm not sure how he fixed it.
                                        https://www.youtube.com/watch?v=iJQIbeiXhsg
                                        My transistor (NPN I believe is getting 0.39 V on top pin, then 0.823 V (same as VCC on memory) on bottom right, and about 0 V on bottom left. I don't know why it's not getting 5 V on top pin??
                                        • PNI E.
                                          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                          by PNI E.
                                          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                          03-17-2025, 04:23 AM
                                          09-07-2024, 05:50 AM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
                                        • mrautom8
                                          Samsung TV UN75H6350AFXZC main board schematics?
                                          by mrautom8
                                          Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                                          Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                                          While relay is on, all voltage rails are present and steady (scoped) on main board.
                                          I love a good logic puzzle but getting lost without any schematics.
                                          No shorts on ANY capacitor main board.
                                          Thermal camera shows 3.3V inductor getting warm instantly but...
                                          10-19-2025, 06:32 PM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
