Samsung QE65Q800TAT
  • amennone
    • Feb 2015
    • 63
    • italy
    Samsung QE65Q800TAT
    Defect: Off, voltages on the power supply ok.
    When you press the power button, the TV makes a clicking sound (activates the relay),
    the Power LED continues to remain off.
    The 13 volt voltage on the power supply is ok.
    By disconnecting the cable from the main board to the power supply, the TV backlight turns on.
    I suspect the flaw is the main board, any suggestions are valuable.
    I couldn't find any wiring diagrams online.
    BN44-01068A LED DRIVER BOARD
    BN95-06565A T-CON
    BN41-02752A MAIN AV BOARD BN41-02752A (BN94-15931K) - SAMSUNG
    BN44-01073A Power board
    BN40-00338A BN94-15301NJ TUNER-DTV AIR CABLE
    CY-TT065JMLVCH
    BN95-07056A Samsung LCD/LED-panel
  • Diah
    • Feb 2013
    • 6366
    Re: Samsung QE65Q800TAT
    8K SAMI... kinda of joke ... take out the black heat sink complete and post photos for yours boards up down side photo as well close to SPI and if you able to make dump of it.
    • amennone
      • Feb 2015
      • 63
      • italy
      BN95-06565A T-CON
      CY-TT065JMLVCH
      After more detailed checks, the power LED turns on, stays on for about 5 seconds, then turns off and on again. The relay turns on and off, like the power LED, in an infinite loop,
      in all this the backlight remains off.
      • amennone
        • Feb 2015
        • 63
        • italy
        Dump W25Q40CL
        • amennone
          • Feb 2015
          • 63
          • italy
          можно ли получить дамп spi w25q40, спасибо
          • Diah
            • Feb 2013
            • 6366
            disconnect the cable between power boards and the Main board.. then plug it in wall.... check if the back light will turn on
            i see you did it before... then how about disconnect one if the LVDS and turn on.... BL come on ?
            • amennone
              • Feb 2015
              • 63
              • italy
              Disconnect the LVDS cable, the backlight is not present. 25Q40 is definitely corrupt.
              I need the dump of 25Q40.
              Thanks for your interest
              • electro.hd
                • Aug 2018
                • maroc
                Thank you for your interest and cooperation in this topic
                • electro.hd
                  • Aug 2018
                  • maroc
                  If someone or a member of the forum needs to DMP emmc I read it from the motherboard. (I have it) Thanks everyone
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • Asraf Atb
                    by Asraf Atb
                    01-27-2025, 05:02 PM
                  • mrtek
                    Vizio M65-C1
                    by mrtek
                    Hi.
                    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                    07-14-2025, 07:28 PM
                  • C152Heavy
                    by C152Heavy
                    Summary for TL-DR readers:
                    • VCC pin (18) of PFC...
                    01-11-2023, 02:53 PM
