Mitsubishi WD-Y657 (WD-65733/V36 Chassis) Blinking Timer Light
  • mrc3270
    • Oct 2010
    I have searched and searched to find an answer, or even a clue, as to what might be causing my blinking timer light problem. Lots of info around on older Mitsubishi DLP units and the capacitor issues which have plagued them, but little to nothing on this newer model (Mfg in 2007).
    When the unit is powers on, there is relay activation on the PWB module, but no other activity aside from the blinking timer/power led on the front panel; no picture, no sound...no power to the light engine, the lamp ballast; no fan activity or other relay clicks. I opened up the PWB module to see if there were some DM-board capacitors which may be causing this issue, nothing that seems out of the ordinary. No reaction to error code operational check, using the front panel switch diagnostic doesn't change the blinking light sequence. I get the same result with removing the lamp; if the lamp cover is removed, I do get the proper LED readout.
    Do these units have the same capacitor issue as the older Mitsubishi DLP models? Perhaps it is another component on the DM module? I have validated all fuses on the Power board are good; there is 12V to the DM board, but not to the light engine. Any insight is appreciated!
  • PlainBill
    • Feb 2009
    • 7034
    Re: Mitsubishi WD-Y657 (WD-65733/V36 Chassis) Blinking Timer Light
    Service manual I've got an earlier model (WD-65732). IIRC, they discuss the various light patterns.
    PlainBill
    • YasaCh
      Sony kdl 40p5500 red light keeps blinking 3 times
      by YasaCh
      Hello...
      my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
      i opened the back cover no sign of damage on the powery suply or motherboard
      when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
      another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
      07-07-2025, 11:53 AM
    • Fergal22
      Samsung UE40F5300AK blinking red light
      by Fergal22
      I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
      When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
      I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
      Any help would be appreciated...
      02-02-2023, 09:19 AM
    • matty24
      Samsung UE50MU6172 - red light blinking
      by matty24
      Hello. I have problem with Samsung UE50MU6172.
      TV won't turn on, red standby light is blinking.
      Power supply BN44-00807A is fine. I replaced it with the new one.​
      Main board BN41-02568B (BN94-12530E)
      I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
      03-02-2025, 08:57 AM
    • norbiszoke
      Samsung 50AU7172, only blinking red light
      by norbiszoke
      We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
      Regards, Norbert!...
      04-17-2024, 06:54 AM
    • huzo
      HP 470 G5 blinking amber light no power
      by huzo
      The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
      So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
      I've tried flashing the bios...
      interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
      06-08-2023, 04:08 PM
