Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
  • Vincenzo2
    • Oct 2022
    • 10
    My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
    Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
    I put some pictures here to show that it is labeled "M7". Looked up a website that is called "The ultimate SMD marking codes database" and went over all the items that came under M7 and the only two that made sense (after looking up pictures on datasheets and eleminating all the entries that should have more than two terminals) were a diode and a 24v zener diode.
    I do not know which one to use.
    Is there usually a zener in the backlight driving circuit?
    If I remove this component and push the power button, will I get a bang and turn the tv unrepairable?
    Will a power zener that is 24 volts substitute for both?
    Last edited by SMDFlea; 09-08-2023, 05:41 AM. Reason: Element 32 inches tv (ELEFW328B)
  • R_J
    • 9607
    Re: Unknown component: Diode or zener?
    It is a 1N4007 DO-214 case.
    I suspect it is across the LED feedback resistors PR60~PR63 (those 2R20Ω resistors are in parallel) , that is why it measures low resistance. The led return likely connects to the diode anode and the cathode goes to ground.
    Most led drive circuits use a circuit to boost the base dc voltage (29v) to a higher voltage (90v) these circuits also monitor the led current and voltage and will shut down the circuit when there is an open circuit ie: open led backlight circuit, or if the backlight plug is removed.
    The main/power supply board is likely ok and you have one or more bad led's in the panel
    • Vincenzo2
      • Oct 2022
      • 10
      Thank you. Great information. I measured the low voltage both with LEDs connector connected and disconnected.
      I just did it again. Connected to mains and off (standby), 24 volts and some change, Turned ON, 27 volts and some change and very quick jumps to 90 volts and then goes down quickly to 28v and change.
      Can you give me the general LED's connection (every strip is series, or some other configuration)?
      Does one bad LED turn of that protection circuit you mentioned? or does it have to be severe enough?
      The diode (that you mentioned is equivalent to 1n4007) is not connected to the mosfet in any way but it does look like is in parallel to the 4 parallel 2 ohm resistors (one is actually 2.2 ohms), a connection which is weird if I want to think about an application to diode||resistor.
      I was too lazy too to open all those little screws to get to the LEDs.
      Thanks again
        • 21968
        Re: Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
        Put make and model number in thread title ! ! ! https://www.badcaps.net/forum/showthread.php?t=24661
        • R_J
          • 9607
          Thanks again
          The led's (and the strips) in the panel are in series, so if one is open the circuit is open. The diode is across the 4 current sense resistors in the return line of the led string, not the mosfet, the mosfet source resistors are PR40,41,42 and there is no diode across them.
          The voltage jumped to 90v then the circuit detected an open circuit and shut down the led drive boost voltage.
          • Vincenzo2
            • Oct 2022
            • 10
            Thanks. Missed that one.
            • Vincenzo2
              • Oct 2022
              • 10
              Beautiful!
              Thank you
              Where do you recommend getting schematics like the one you shared?
              • unimatrix93
                TV backlight zener diode
                by unimatrix93
                Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                The led strips has 9 6V leds.
                02-10-2025, 12:13 PM
                NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                by sam_sam_sam
                I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                I bought this from an eBay seller but unfortunately they only had one
                I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                I bought three of from them to also make battery packs with this output power limit in mind
                I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                04-23-2025, 05:50 AM
              • nev1001
                What zener diode might fix the sound on Maestro Mayhem gaming chair?
                by nev1001
                Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                I think an issue could be a zener diode (or capacitor) which has shorted out.
                The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                04-17-2025, 05:09 PM
              • yurik_avs
                Power supply ADP-300ER Zener diode parameters unknown
                by yurik_avs
                Guys, I have a question about the ADP-300ER power supply. While the spare parts I ordered are on their way, I decided to once again check the piping chains of the burnt mikruh. I found the zener diode in a break, so apparently I didn't detect it right away. His positioner is ZD41. Can anyone tell me its voltage? It is located in the harness of the IC41 NCP1612A3 microcircuit
                Here is an extract from the datasheet for this chip. This pin is grounded until the PFC output reaches its nominal level. It is also grounded if
                NCP1612 detects a fault. The rest of the time, i.e. when the PFC...
                12-12-2023, 05:32 AM
              • hobostove
                Corsair RM1000e - Help identify 5VSB Zener diode
                by hobostove
                Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                There's a 22ohm resistor that's melted and open, but it still has the bands.
                The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                It looks like the diode connects the source and drain of a TNY284...
                03-27-2025, 02:25 PM
