Samsung UN32EH4003F
  • Mr_Slim
    • Jun 2018
    • 23
    Samsung UN32EH4003F
    Hi All,
    This TV appears to have a backlight failure. Suggestions where to start are appreciated.
  • handsworth
    • Oct 2015
    • 174
    Re: Samsung UN32EH4003F
    Disconnect cable between the main board and power supply. Backlights should come on when power is supplied. If not, backlights are suspect and prolly need replaced. Also check standby voltage on power supply.
    • Mr_Slim
      • Jun 2018
      • 23
      Thanks, Are you saying that the backlight should come on even though the power switch, (which is controlled by the mainboard) is disconnected?
      Also, where do I check the standby voltage on the power supply?
      • Mr_Slim
        • Jun 2018
        • 23
        Ok, I see 13.8 V on B13 and 5.3V on B5V, so I expect those are the standby voltages.
        When I measure the voltages on the CNL802 connector (the backlight power connector I suspect), (to ground) with the backlight disconnected
        1 (D+) = 131.5V DC
        2 (S-) = ~1.8V (and it seemed like it was discharging)
        4 (S+) = (same as S-)
        5 (D-) = 2V
        with the backlight connected:
        1 (D+) = 130V
        2 (S-) = 16.25V
        4 (S+) = 16.25V
        5 (D-) = 2.2V
          • 12086
          • U.S.
          One thing at a time, what is the result of test from post #2?
          • Mr_Slim
            • Jun 2018
            • 23
            Ok, The backlight does not come on with the mainboard disconnected and power is applied. I see 13V on B13 and 5.3 on B5 as per the board test points. Not sure where else to test for the standby voltages.
              • 12086
              • U.S.
              Ok, the problem, I should say a problem, there could be more, but you need to fix this problem first. Since the test failed, there's a problem in backlights/backlight circuit or powerboard.
                • 12086
                • U.S.
                Look at this thread, I linked a few backlight testing videos, plenty more on youtube: https://www.badcaps.net/forum/showthread.php?t=122728
                • EazyBone
                  • Jun 2023
                  • 1306
                  • United states
                  No need to check MB voltages as it's disconnected and no lights. It's either power board, check voltages coming out to lights, or it's the lights. Sony won't steer ya wrong
                    09-07-2024, 05:50 AM
                  • max789
                    Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                    by max789
                    Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                    I made the following tests:
                    1. Disconnected the main board from Power Board = backlight works.
                    2. Connected the main board and disconnected the T-Con = backlights does not work.
                    So I ordered a main board from Ebay also BN41-02156A but from...
                    01-18-2024, 06:56 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
