Lg 65UB950V No Image
  • Megaule
    • Aug 2023
    • 18
    • Italien
    Hello, i have this Tv that stops working. When i turn on the LG logo in the front will light up and fade out. I hear the relays clicking and they works, because i replaced them!! I have the 3,5v standyby, when i power on the tv i have also the 12v and 24v! Only the "82,2v" for backlight is missing. On the mainboard the Led ld2300 is on. The led ld1900 (its for tcon =on i think) will shortly light up then go out. I have no Drvon and also the 12v for tcon supply is missing. After ca 15 seconds the led on the power supply board will flash 5 times then pause then 5x....and so on... Errorcode??
    Audio i do not hear. Also witha flashlight on screen i will see nothing....
    Can someone help me please?
  • Megaule
    • Aug 2023
    • 18
    • Italien
    Re: Lg 65UB950V No Image
    The pwr supply board is lpg5565-14ul12
    Or eay63149101
    • nomoresonys
      • 12328
      • U.S.
      Good straight on pictures of each board and one of the whole back as to see how everything is connected, and a clear picture of the map/legend of the expected voltages on the powerboard, should be close to connector marked P801 or similar.
      • Megaule
        • Aug 2023
        • 18
        • Italien
        Hello here are the fotos, the relays are working... Even if it don't look so🙈😬
        • An-klamm
          • Feb 2023
          • 43
          • Deutschland
          I had a 65LA on me the other day with similar issues.
          After you have removed the thermal pads, you can use a hair dryer to heat the CPU on the motherboard a little (10-30 seconds was enough for me) and then try to start the TV.
          It worked for me.
          I then reflowed the CPU and the TV ran until the "customer" picked it up and put it in his car.
          Screen breaked....
          • Megaule
            • Aug 2023
            • 18
            • Italien
            Hi An klamm, thanks for your answer, what for an ic is the cpu?
            • An-klamm
              • Feb 2023
              • 43
              • Deutschland
              Just heat the yellow marked area for about 30 seconds (after you take off the soft pads) and then you can test it.
              If that works, then you can let it cool down completely and try only one IC etc. Then you can narrow it down.
              On mine it was on the red marked one as far as I know. But it is already 2 weeks ago.
              • Megaule
                • Aug 2023
                • 18
                • Italien
                So i heated up this area, but nothing... Same problem. But i tried to heat the chip on the tcon and i noticed that after heating the tconchip the led on mainboard that lights up when tcon is on (i think) will light for about 2-3 seconds. When the tconchip is "cold" it will be light up only for a moment about 0,5sec when i try to turn on the tv
                • Megaule
                  • Aug 2023
                  • 18
                  • Italien
                  Now i conected the tcon 12 v supply direct to the psb, and the light zhat shows tcon = on on the mainbord will go on and remain on. But the "errorled" on psb flashes 5 times like before... So same error!!??
                  • Megaule
                    • Aug 2023
                    • 18
                    • Italien
                    Always with 12v directly conected to tcon i pull up the drvon signal to 3,5v with 1k resistor. Same problem only that the errorled flashes 7 times now....
                    • Megaule
                      • Aug 2023
                      • 18
                      • Italien
                      So i test only the psb, with mainboard and tcon completly disconnected. I pull pwron and drvon up to 3,5v with 1k resistor. I have all votages, 12v and 24v. The 82v for backlight goes on 72v ca but only for 3-4seconds, the backlight will turn on for this time, then the bl voltage goes to zero and the errorled flashes 3 times!!
                      • Megaule
                        • Aug 2023
                        • 18
                        • Italien
                        I tested also the caps on the psb... All ok...
                        • nomoresonys
                          • 12328
                          • U.S.
                          Kinda seems like a backlight issue.
                          • Megaule
                            • Aug 2023
                            • 18
                            • Italien
                            When it is so, then i do not understand why the system don't light up the backlight, and then the system "see" that there is a problem and told the drvon signal and goes in error state. But when i spower on the tv, there isn't a drvon signal, will mean the tv do not get "test" the backlight.... Probably the mainboard is in permanent error status!?!
                            Excuse my english, but i hope you will understand me....
                            • nomoresonys
                              • 12328
                              • U.S.
                              Post #11, that pb stand alone test, where you turn on the powerboard, should bring the backlights on, that's why I'm thinking it's problem in backlight circuit or powerboard.
                              • Megaule
                                • Aug 2023
                                • 18
                                • Italien
                                Yes in this case the backlight go on for 3-4 seconds then go out... You mean if the backlight are good, so in pb stand alone test they have to remain on, if i understand right...
                                • Megaule
                                  • Aug 2023
                                  • 18
                                  • Italien
                                  Is there any service manual of the tv or power bord to identify the flashing led error codes??
                                  • nomoresonys
                                    • 12328
                                    • U.S.
                                    Yes, affirmative.
                                    • nomoresonys
                                      • 12328
                                      • U.S.
                                      I'll let the others help you with that, I dislike manuals, they make it too easy.
                                      • Megaule
                                        • Aug 2023
                                        • 18
                                        • Italien
                                        How can i test the ledstrips without a specific backlight tester?
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                          HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 10:56 AM
                                          HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
