ps50q97HD still clicking after reflowing q801 & 802, any ideas?
  • reidy-
    • Jul 2010
    • 18
    Hi, I have taken in a 50" sammy plasma with the default clicking sound, upon inspection the q801 & 802 transistors legs were browned and the solder joints cracked so I reflowed them.
    the fault reamins, I havnt tested for voltages yet but was wondering where to start, should I disconnect all sub board bar the main AV board and try power it up and see if it still trips out?
    I have read somewhere that the sub 2 board on the PSU can fail what am I checking for? I grabbed a service manual for the TV but it wasnt much use with a very basic PSU trouble shooting guide.
  • reidy-
    • Jul 2010
    • 18
    Re: ps50q97HD still clicking after reflowing q801 & 802, any ideas?
    well here's a strange one...
    by the looks of it there is a 42" PSU powering the TV inplace of a 50" PSU despite the label on the rectifier heatsink suggesting otherwise.
    I transplanted my current PSU from my owrking 42" plasma to the AV board which powered up instantly (as expected) with the relay clicking once, then about 5 secounds later a nice little tune comes from the TV suggesting that its on.
    from what I can see visually
    50" PSU: http://assets.shopjimmy.com/media/ca...bn4400162a.jpg
    42" PSU: http://www.zemtronix.com/static/plazma_repair_1.jpg
    there is very little difference between the two boards (if any other than the colour and presumably rating of the main transformer) would I be ok to try power up the TV fully with the 42" PSU for short periods of time?
    What I am worried about is damaging the PSU with regards to the (presumably) failed Y sustain
    • reidy-
      • Jul 2010
      • 18
      Wow this site needs the ability to edit posts:
      now update; TV is totally shot with faulty bufferboards & y-sustain missing caps and a MOSFET :S
      still I wouldnt mind getting the PSU back in opperation but I dont fancy transplanting all known working MOSFET's from my 42 to the 50 PSU
      • Wizard
        • Mar 2008
        • 2296
        dump that 50" unless you find exact model of smashed plasma panel donor to rebuild your 50".
        The 42" and 50" SMPS (power supply) are built differently for power handlings. Do use same boards correctly please.
        Cheers, Wizard
        • Sisko
          Onkyo-593 No power and now clicking sound
          by Sisko
          Hi all!!
          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
          10-03-2025, 02:18 PM
        • B0r1s
          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
          by B0r1s
          PSU - BN44-00878A
          Symptoms:
          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
          A weak clicking sound was coming from the transformer.
          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
          Progress:
          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
          01-17-2023, 04:58 PM
        • slimmy182
          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
          by slimmy182
          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
          Looking on google I found this:...
          01-14-2023, 11:55 AM
        • beetle1303
          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
          by beetle1303
          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
          01-13-2025, 08:49 PM
        • Stefan Steff
          HP Elitebook 840 G5 strange behaviour, need ideas...
          by Stefan Steff
          I finished my work for this year, so I'm free until January 6th.
          My last task it's unresolved and I'm looking for ideas for the return in January.
          So what's about...
          This laptop is booting in 3-4 seconds has no password and every voltage is present. So far so good.
          My problem is that it doesn't boot from anything. !...just stays with a blank screen(backlight only)
          No USB boot (in fact partially no boot...), no PXE boot nor boot from M2.SATA or NVME...crazy...
          The Ventoy USB (EFI) boots in the menu system but after selecting one of the ISO (like a simple...
          12-24-2024, 05:50 AM
