Invid PN1B-8X8NH Nvr Unknown IC
  • Herbssat
    • Sep 2011
    • 194
    Trying to identify this IC near the 12 and 5 volt connector. It is marked MDME and looks to be some kind of voltage regulator for the 12 and 5 volt rail. This is located in an Invid Nvr #PN1B-8X8NH. As you an see from the picture it is a 6 pin small ic. Any help is appreciated.
  • R_J
    • 9623
    Re: Invid PN1B-8X8NH Nvr Unknown IC
    Looks like a Ricoh RP154N028B Small dual ldo regulator outputs of 2.8v(pin1) and 1.0v(pin4) input (pin2)
    The picture is too out of focus to be of much use.
    • Herbssat
      • Sep 2011
      • 194
      Thanks Rj. Will check the output pins but pins 4 and 5 have 12v and 5 volts if not mistaken. Will get a better picture up. Thanks.
      • Herbssat
        • Sep 2011
        • 194
        Here is a pinout and voltage reading for this ic acquired from another nvr.
        Pin 1 - 0.600vdc
        Pin 2 -11.96vdc
        Pin 3 -0.00
        Pin 4 -12.09vdc
        Pin 5 -5.0vdc
        Pin 6 -8.20vdc
        • R_J
          • 9623
          I guess that is not the ic, it might be a custom marking? does the other nvr have the same ic top markings?
          What are the ic voltages on the non working nvr?
          Pin 3 seems to be ground, are 2 & 4 connected together? pin 1 looks like a control line?
          • Herbssat
            • Sep 2011
            • 194
            Actually not Rj. Looks like the other nvr has the marking beginning with NY. It is burned so i cant read the full marking. Same circuit though. This is a pain finding these tiny components while the schematic diagrams are somewhere locked away. Thanks for trying to help.
            • Herbssat
              • Sep 2011
              • 194
              There is no continuity between pins 2 and 4. Thanks.
              • R_J
                • 9623
                NY seems to be a Ricoh R5323N030A which has a different pinout
                • Herbssat
                  • Sep 2011
                  • 194
                  Pin out is the same on both boards even though I can't determine voltages on the non working board. Same inductor and capacitors on both boards. Looks like a lot of these markings are cryptic as none of the databases show them. Hard to fix something when components can't be identified.
                  • R_J
                    • 9623
                    Try and draw out the circuit if you can, then it might make more sense. I can't see where the pins go or what components are connected to it based on that picture.
                    • Herbssat
                      • Sep 2011
                      • 194
                      Here are some more pics. Thanks for your assistance.
                        HP 280 G2 Small Form Factor PC i3-6100 Specification for Upgrade or Repair
                        This specification for the HP 280 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 280 G2 Small Form Factor PC boardview and 280 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        09-12-2024, 03:44 PM
                        HP ProDesk ProDesk 600 G2 Small Form Factor PC ProDesk 600 i5-6500 Specification for Upgrade or Repair
                        This specification for the HP ProDesk ProDesk 600 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Small Form Factor PC boardview and ProDesk ProDesk 600 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-12-2024, 03:36 PM
                        HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i5-4570 Specification for Upgrade or Repair
                        This specification for the HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                        09-12-2024, 03:28 PM
                        HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i3-4130 Specification for Upgrade or Repair
