Samsung UE55NU7026K always restart
  • avalente123
    Avalente
    • Dec 2017
    • 9
    • Portugal
    Hello
    I have one LCD TV SAMSUNG UE55NU7026K and it starts, blink 2 times led, backlight on then about 4 seconds, restart again, but no logo appears on the screen. I disconect the power supply cable to the Mainboard and power is ok and backlight also ok.
    With the mainboard BN94-12869G connect, the voltages are ok, 13 Volts and 3,3 Volts also.
    I know that the problem is mainboard, but could be the software?
    I try to find firmware for this mainboard but can´t find
    Can any one give me some help?
    Thank you
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Re: Samsung UE55NU7026K always restart
    This is a panel short. Disconnect one of the tcon ribbons going from the main board (if there's 2) and turn the TV on. Which ever one allows the TV on will be short. Investigate this first before replacing anything. Next, you can sometimes "repair" the tv slightly so that it's usable. Sometimes it appears perfect sometimes it will flicker or have lines or whatever by using a piece of tape to find the short on one of the pins. There is some YouTube videos about this. Before researching see if disconnect a cable will turn it on
    It is not the main board most likely. I am new to this but I literally had a TV doing this yesterday and it's 100 percent a panel short in my case. For you, we will see. A piece of tape will tell you. Good luck
    • avalente123
      Avalente
      • Dec 2017
      • 9
      • Portugal
      I forget to tell that already take out the flat cable to the panel from mainboard. For now it is not the panel.
      • EazyBone
        • Jun 2023
        • 1362
        • United states
        You need pictures for us. The whole back as a whole and each individual board
        • alfatv
          • Sep 2020
          • 353
          For now LOL
          • avalente123
            Avalente
            • Dec 2017
            • 9
            • Portugal
            Here the photos from TV
            • lotas
              • Jan 2016
              • 4879
              • Russia
              You have two loops, so that the TV would turn on without these loops disconnected from the panel, you need to put a jumper on the motherboard between the points FB_TRDY_1 and FB_TRDY_3.
              • avalente123
                Avalente
                • Dec 2017
                • 9
                • Portugal
                i made jumper between the FB_TRDY_1 and FB_TRDY_3 but same problem. I will buy a used mainboard for test. Then i wiil write results. i am afraid that panel have something wrong, but need to find
                • zwarder
                  • Oct 2013
                  • 46
                  • United Kingdom
                  Try blocking ckv lines with tape method worked for my 6 series
                    09-07-2024, 05:50 AM
                  • fulepost@outlook.com
                    Samsung "QE" series QE55Q70RATXXC Intermittant restart in "home mode".
                    by fulepost@outlook.com
                    Dear all.
                    I'm a less knowledgable member who would appreciate some guidence.
                    I have a Samsung QE55Q70RATXXC that works perfectly in "shop mode" but in home mode it restarts, Intermittantly.
                    With intermittant I mean the TV can work perfectly for a week and suddenly start to restart. Before the restart it may reach different stages. Sometimes it restarts when the "QLED" start screen shows up and some thimes it restarts after hours, and everything in between.
                    When the restart occurs, the screen blacks out leaving a light area alomng the edges fading...
                    11-09-2025, 07:10 AM
                  • stylishconsultant
                    un60j620dafxza - Samsung No Display Problem
                    by stylishconsultant
                    Hi All,
                    Need help.
                    I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                    So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                    problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                    might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                    09-04-2024, 03:26 AM
                  • Nairolf
                    Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                    by Nairolf
                    I have a Samsung DM32D display.
                    When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                    Here’s what I have tried so far:
                    1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                    2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                    3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                    From these tests, I suspect the problem might be on the mainboard. Could anyone...
                    08-24-2025, 03:47 AM
                  • bohaboha
                    ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                    by bohaboha
                    Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                    04-19-2025, 01:47 PM
