Lg 50pk250
  • VivianLarrieu
    • Jun 2023
    • France
    Lg 50pk250
    I found a LG 50PK250 but on the first test, the TV does not have image, just sound.
    I check some voltage, Va and Vs have some stability problems and I found that some soldering should be repaired. After that, Va and Vs are good.
    The D1 blinks on the controller board, the TV is live, but still no image...
    I check others voltage, all others seems good except VSC and VY. They are close of 0.
    So, I suspect the Y-Sus board have one or more components to change.
    I check all FET and found some to be replace (Q405, Q408, Q412, Q414 & Q415).
    I check all Y-Drive connectors (upper & lower) in diode mode and I do not found any problem.
    I also check the different internal voltage, FG5V, FG10V, FG11V, FG15V, FG24V and 18V are good.
    I also check the Y-Drive boards for shorts and do not find any problem (check all connectors in diode mode... long process).
    So, I order the five FET and change them.
    Then, I connect the Y-SUS board again without connecting the Y-Drive boards.
    Power-up... no VSC & VY, still around 0.
    I try again with the Y-Drive boards in case the load is not sufficient to start correctly the board.
    This time, one of the new FET (Q405) exploses....
    I suspect another problem, but I need your help to find the problem.
    Vivian
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Lg 50pk250
    The new ones are probably fakes from China. Always test new ones before installing.
    • VivianLarrieu
      • Jun 2023
      • France
      Re: Lg 50pk250
      Thanks for the advice.
      Where do you recommand to purchase these 30F124 ?
      I found only some on ebay.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Re: Lg 50pk250
        It's been along time and I can't remember who I bought them from. Ebay doesn't go that far back for me to check either. My advice is order from someone that posts a picture that looks like the original and takes returns. I explained that I know how to test them and then they refunded my money without having to send the fakes back to them.
        • R_J
          • Jun 2012
          • 9588
          Re: Lg 50pk250
          It is also possible that when the mosfet shorted it also damaged the gate drive circuit as well.
          • PlasMatt
            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
            by PlasMatt
            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
            09-20-2025, 06:50 PM
          • legg
            LG 42PC3 buffer output doesn't follow YSUS
            by legg
            LG42PC3D -UD originally with green lamp but no display or audio.
            Owner says was working, then went 'pop'.
            All 5V caps bulging. replaced.
            All PSU output voltages within spec but -Vy is low on YSUS.
            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
            eventually shorts DG. Replaced all 3 - -Vy now OK.
            Y scan buffer test point does not follow YSUS output below -50V
            Note: This unit seems to expect YSUS output to park at -Vy in between
            drive signal pattern periods. A replacement drive signal board confirms this....
            11-18-2021, 11:49 AM
          • Truncatedhose
            Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
            by Truncatedhose
            Greetings all!
            Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
            Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
            07-04-2018, 10:59 AM
          • zwarder
            eax61319402 50PJ350 YSUS
            by zwarder
            Hi
            Had shorted YSUS
            Q24 RPJ63F3
            C726 cap
            Q11 K3667
            R528 & R529 2.2 ohm
            replaced all of these but still trips psu VS & VA are a bit low when ysus disconnected. IC301 does look a bit burnt however
            ZSUS is also good as far as I can tell
            Anyone could help me out on this one
            10-23-2023, 08:11 AM
          • maces
            LG 60PH6608 YSUS repair
            by maces
            Hello all,
            I have a problem with my LG 60PH6608. The TV is only clicking and doesn't get started.
            I checked the power supply and measured that the 200V is shorted at the YSUS board.
            All IGBTs, the MOSFET K8A60DA and the diode D603 are shorten.
            So I replaced the parts. I checked the further parts for shorts and I was pretty sure that there is no further problem on the board.
            So I plugged it in. Directly, resistor R251 (2,2 Ohm) blowed out with a little spark. Immediately I disconnected the TV from supply.
            I checked the replaced parts (IGBTs, MOSFET...
            12-11-2022, 02:21 AM
