Samsung ue55d8000yuxxu turning on/off and clicking
  • LGhost
    • Apr 2023
    • 5
    • Portugal
    Hello everyone! This is my first thread asking for help and I'm new here so please be nice
    I'm trying to repair a Samsung TV but not having much success so I've came across this forum and it seemed kinda nice and friendly. The TV is clicking on/off (relay) and I can't seem to put my finger on the issue. The image looks fine (since I can get a glance at the "Smart TV" logo when it boots). But it's just an endless loop of on/off. If I disconnect the mainboard from the PSU it stops doing the "clicking" sound but that's about it. I've already got a used mainboard and PSU thinking it was either one of those the issue but the issue still presists which is weird. Do you guys think that I might have gotten a damaged used PSU or mainboard? Or what could the issue be?
  • lotas
    • Jan 2016
    • 4652
    • Russia
    Re: Samsung ue55d8000yuxxu turning on/off and clicking
    The problem is in the backlight, please note that in this model the backlight will not turn on with the mainboard turned off.
    But there is a problem in the eMMC firmware.
    • LGhost
      • Apr 2023
      • 5
      • Portugal
      Is there any way I could test for that?
      I've disconnected everything from the mainboard and PSU and keept them both connected together and it still does the "clicky" thing (that's the reason why I thought the issue was with one of them).
      • An-klamm
        • Feb 2023
        • 43
        • Deutschland
        What PSU and mainboard is used?
        • LGhost
          • Apr 2023
          • 5
          • Portugal
          The PSU is The bn44-00428a
          And the mainboard is the bn41-01622 (have to check if it ends with a, b or c).
          • An-klamm
            • Feb 2023
            • 43
            • Deutschland
            Please provide pictures of the power supply. Especially of the voltages that are next to the connector.
            • LGhost
              • Apr 2023
              • 5
              • Portugal
              Update: Ended up being indeed the backlight. At least I think it was. I didn't finish the job but it is working now without one strip of the backlights. For anyone in the future with the same issue, this is what I did: I simply cut one of the wires on the cable that connects the PSU board to the Mainboard. That wire was the backlight PWM. There was 4 wires, each controlling one horizontal strip. I tested them one by one and once I got the fourth wire then the TV turned on and was on and alive again!
              Thanks for all the help
              • Nairolf
                Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                by Nairolf
                I have a Samsung DM32D display.
                When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                Here’s what I have tried so far:
                1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                From these tests, I suspect the problem might be on the mainboard. Could anyone...
                Yesterday, 03:47 AM
              • Kjell
                Samsung Series 9 - BIOS issue
                by Kjell
                After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                08-01-2025, 09:15 AM
                09-07-2024, 05:50 AM
              • alltvrepairs
                Samsung HG49EE690 Hospitality TV reboot issue Mainboard BN94-11086A
                by alltvrepairs
                I have 3 of these TVs for repair with same problem of going to standby after around 10minutes and start again continuously. I have tried a new SPI 25Q40 but fault remains. Am suspecting a CPU problem as it gets a bit hotter than I expect.
                This seems to be a common problem in these models. I am 100% sure it is a mainboard issue as I have fitted a spare from a normal TV from a UE40K5607 and stays on (diplay inverted but I managed to rotate in SM using a different display).
                Any help appreciated!...
                03-14-2024, 03:39 AM
              • vincentedel
                Samsung SyncMaster 740n Phase Control Issue
                by vincentedel
                I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                04-22-2025, 12:33 AM
