samsung ue55ju6800 change backlight strip
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi to all i want to change the backlight strip on the above model
    do you know if there is someone helpful video with similar model whith mine ?
    thanks on advance
    • 12206
    • U.S.
    Re: samsung ue55ju6800 change backlight strip
    Here's one you might want to check: https://www.youtube.com/watch?v=2Wo_uVzzvPc
    • Xristakis795
      • Mar 2021
      • 162
      • Greece
      thanks a lot for the answer sir
      I was hoping for a video with more details in disassembly
      only the LEDs are visible on this one
        • 12206
        • U.S.
        here's one, be sure and also check those connections in the first video: https://www.youtube.com/watch?v=KvI7nMP2_M0
        • Xristakis795
          • Mar 2021
          • 162
          • Greece
          so its the same with mine model the only difference is the inches 75 instead 55 right sir ?
            • 12206
            • U.S.
            Should be, just take your time and remember to treat that panel gently, VERY easy to break/crack them, maybe check some youtube videos for safely removing panels.
            • Xristakis795
              • Mar 2021
              • 162
              • Greece
              ok sir i understood
              this model is only led tv no qled right ? just has display with nano crystal
              i have found and this address
              https://www.youtube.com/watch?v=oI52B4ba2Dg
              i will check as you told me
              you are very helpful sir thanks a lot
                • 12206
                • U.S.
                Yes looks pretty straight forward, picture of the backlights there, looks like 18 pieces: https://www.ebay.com/itm/15534224245...3ABFBM5J-5u_Nh
                  09-07-2024, 05:50 AM
                • kdaniel
                  Samsung UE55JU6800 Issue with new backlight
                  by kdaniel
                  Recently bought faulty Samsung UE55JU6800 which when collected was faulty and was not turning on or at least there was jo picture on it. After taking it home and turning it on the TV was working fine.
                  However, there were dark spots all around just like faulty backlight looks like. After replacing the backlight for new one, there is the same issue where black spots can be seen at the point of each led.
                  Any advice ore recommendations what could be the possible issue? Could it be cheap backlight i got from china?
                  Thanks in adv...
                  11-03-2022, 06:12 PM
                • sansanpartida
                  Samsung QE82Q70RAT no backlight
                  by sansanpartida
                  Hi everyone!
                  Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                  My issue: No backlight.
                  Model: QE82Q70RAT
                  Type No: QE82Q70RAT
                  The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                  So hopefully, I can fix this cheaper.
                  05-22-2024, 06:56 AM
                • howardc64
                  Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                  by howardc64
                  TV was fixed just after removing Samsung's rear snap cover.
                  This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                  Maybe PSU->backlight connector didn't have a good contact?...
                  07-23-2025, 12:34 AM
                • Warrensmith
                  Samsung BN44-00807E Low Backlight
                  by Warrensmith
                  Symptom is dim backlight - this set came in with almost no backlight.
                  Samsung UN55JU6500FX2A
                  1 - Replaced all backlight LED strips (set had lots of hours at level 20 backlight)
                  2 - Changed out what appeared to be a bad Q9102C on BN44-00807E - not shorted or burned but appeared to be open. I was able to read (with difficulty) the part number - however I may have misread it - Can someone confirm that this is indeed an AOD9N40.
                  Backlight improved significantly - about like it would be set to a level 3 or 4. Setting all the way to 20 seems to...
                  10-27-2022, 07:09 AM
