Samsung QE65Q60TAUXZT New Mainboard but wrong colours
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4518
    • Italy - Milan
    Re: Samsung QE65Q60TAUXZT New Mainboard but wrong colours
    there is a page where you can see all input settings, can you show the differences? Anyway maybe the service manual don't covers all the differences in settings, if i remember there is a page where you can set color settings for each input but it seems that it does not recognize a valid input so the inputs page must be seen, in second place a complete settings data copy must be made but i surely don't know how, i have never played that long with a Samsung, maybe the new mb has something wrong in settings files, so a new board is required..
    • Diah
      • Feb 2013
      • 6500
      you have only T-CON firmware Data on replacement didn't match
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4518
        • Italy - Milan
        Try also even a software update, i remember that on some newer Samsung there is also a spi memory on the panel's boards, maybe that must match some data with the tcon section.. i don't know what the hell it stores, maybe them needs a pairing procedure like in Sony..
        in post #16 i see on the option page at voice Writing front color there is no signature, what happens if you select that line? Is that selectable or is read only?
        • nomoresonys
          • 12312
          • U.S.
          Do the sticker numbers match on both the mainboards? if you followed option byte instructions of lotus pdf it should have worked, guess it's possible they sent you a defective board.
          • alltvrepairs
            • Jan 2014
            • 256
            • Malta
            Yes tks. But didn't find from where to update. Looked in all Factory settings.
            • alltvrepairs
              • Jan 2014
              • 256
              • Malta
              #26
              It is not a requirement apparently as it is empty in both boards
              • alltvrepairs
                • Jan 2014
                • 256
                • Malta
                #27
                These are both stickers and the noticed difference
                • lotas
                  • Jan 2016
                  • 4809
                  • Russia
                  #28
                  Try to look through, clean the contacts on the LVDS cable on both sides.
                  • Diah
                    • Feb 2013
                    • 6500
                    FW data wasn't No to change and its difficult to pass all SM setting for LVDS depth.. . so its version. need to play firmware downgrade in case upgrade wont work
                    did the tV had integrated or Separated t-con.?
                    • alltvrepairs
                      • Jan 2014
                      • 256
                      • Malta
                      #30
                      Integrated T-CON.
                      I have sent information to Samsung local agent whom are to verify if board is defective or not. Hope will get a reply soon as my client wants his tv back.
                      • alltvrepairs
                        • Jan 2014
                        • 256
                        • Malta
                        #31
                        Same cable used for both boards on same Display. LVDS connector in new maniboard looks new with shining pins
                        • Diah
                          • Feb 2013
                          • 6500
                          Integrated T-CON.
                          aha then different version of MB .... in thus case search after yours panel code if listed at _SM
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4518
                            • Italy - Milan
                            #33
                            if the problem was electrical at the lvds port the tv would not tell failure for the tv mode (input) i guess, i think that this board has some problem at main software, totally waste of time..
                            • alltvrepairs
                              • Jan 2014
                              • 256
                              • Malta
                              #34
                              Update:
                              A new main board arrived and all is now fine. The connected new Pcb displayed the correct colors immediately even before programming of panel type, model , local etc.
                              Thanks ALL for helping me out, as usual!
                              • nomoresonys
                                • 12312
                                • U.S.
                                #35
                                Nice, glad you solved it, was quite a puzzle.
                                • nomoresonys
                                  • 12312
                                  • U.S.
                                  #36
                                  Were the sticker numbers on the new board that worked the same as the replacement that did not, meaning was the last letter the same or was it the same as the mainboard you have that already worked or different yet?
                                  • nomoresonys
                                    • 12312
                                    • U.S.
                                    #37
                                    Trying to discern if the board that did not work was a mismatch or just defective.
                                    • alltvrepairs
                                      • Jan 2014
                                      • 256
                                      • Malta
                                      #38
                                      The board received by ordering with the full model number had a different BN number.
                                      Received BN94-15427H and worked fine immediately.
                                        09-07-2024, 05:50 AM
                                      • Nairolf
                                        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                        by Nairolf
                                        I have a Samsung DM32D display.
                                        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                        Here’s what I have tried so far:
                                        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                        From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                        08-24-2025, 03:47 AM
                                      • bohaboha
                                        ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                                        by bohaboha
                                        Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                                        04-19-2025, 01:47 PM
                                        09-06-2024, 11:40 PM
