Re: Samsung QN75Q60TAF Boot Loop fixed but no picture
yours Photo
with out masking.... you test to turn on after
A- remove SPI IC 601
@howardc64, the 12 ohms was measured on the main board, i believe you mentioned R89 earlier being an inductor. It was all caps around that.
@diah, mask on, 35/36 at MB side is 3.272VDC on both pins to gndLeave a comment:
Yes, thats a good test. If you have a sharp probe tip + steady hands, can try the exposed contacts on the LCD cable connector. Another place might be those 2 board through holes coming off the pins. Will need to remove tiny bit of insulation to expose the copper trace. I have very sharp (like sewing needle) probe tip that can be pushed and turned a little to remove the green insulation. Anyway, can try sewing needle. Don't press too hard since they are fragile small copper traces. I guess careful scrap from Xacto knife tip will do too.Leave a comment:
What is the minimum connection configuration that will reproduce the 12ohm reading in post #23? Can you post a pic of this cap and any labels around it?
Ideally within a single buffer board but make sure reproduce it first.
4x buffer boards also can provide patterns for comparison. If the 12ohm short is reproducible in 1 buffer board, are there similar circuit elsewhere for comparison?Leave a comment:
No difference with all cables connectedLeave a comment:
I will check, thanks.Leave a comment:
Masking changes circuit connectivity. Might be best to not have it while hunting for the short.Last edited by howardc64; 04-13-2023, 04:23 PM.Leave a comment:
Checked every single capacitor on the buffer boards. No shorts that I can find. That means it's in the panel then, correct? Isolating the VDD (35/36) just removed the ability for the short to affect the VDD supply right? So beyond capacitors, what? Anything?Leave a comment:
LVDS rail P 35 & 36 they are not the main short circuit... they are VDD. so making them mean shutdown Panel / TV booted ..., the seeking after short should be LVDS disconnected.. DMM on Diode mode black probe to buffer boards GND and the red probe move it on all caps ESD D first.Leave a comment:
Yes, you have to unplug the LVDS cable and unplug the U-flex between the brackets on one side.Leave a comment:
Great information, thank you @howardc64.
When I'm doing the continuity checks from the test points to ground, do i do this with the LVDS cable disconnected?Leave a comment:
Here are some steps
Confirm test point shorts
In post #14, you traced masked off pins 35/36 to test points on the board. This is likely a shorted rail. Since you masked off these pins, no voltage is sent to these rails from main board and so TV continues to operate. But of course some power section is lost to the buffer board/panel
Put positive multimeter tip on the test point and negative on ground (TV metal chassis that boards mounts on (usually many GND pathways from buffer boards to chassis) or some of the open copper rectangles on the buffer boards which are usually also GND and read the resistance. Maybe you will see 12ohm again like post #23.
If short on buffer boards, which one?
If there is a short on the buffer board, then need to determine which one. First, can you post a pic of the entire back of the TV? Looks like you have 1x main board to buffer board flex cable. I'm guessing for a 75" TV, there are 4x buffer boards and 3x dark orange colored flex that join them. Your short could be on any of the 4 buffer boards as voltage rails goes to all of them.
To find out which buffer board has the short. First confirm the short on a particular buffer board, then remove the flex to other buffer boards/main and check the short again against the GND on the buffer board. If disappears, then short is on other boards. If remain, then its this one. Probably check all 4 buffer boards in this manner.
Which component is shorted on the buffer board?
This requires even more skill and experience as there are many components and usually multiple caps on every voltage rail. Pros inject voltage (need to estimate how much voltage and max current limit given the circuit) by bench power supply and use a thermal imager (and often a macro lens + video recording) to quickly which component heats up first. There are other ways... by touch, evaporating rate of isopropyl alcohol etc.
Lets confirm you have short on the buffer boards and which one first.
Probably can skip the main board for now, The R82 is an inductor and just a loop of wires so it will read continuous. Anyway, its next to TI TAS5749M which google says is an audio IC and your speaker connectors are just below that.
Here is a annotated pic of your main. The red rectangle is where all the voltages for the LCD panel comes from. Rectangular chip in the middle takes 12v from PSU and generates all the voltages for the LCD (vgh ~= 20v+, vgl ~= -10v, vcom ~<= 10v) so don't go probing around the tight pitch pins around this chip. The octagons are inductors and they will probably read the voltages I gave you above (+ probe on either side of inductor, - probe on TV chassis GND). vgh/vgl/vcom are used to turn each TFT (thin film transistor) at each subpixel (R,G,B) and turn the LCD polarizer to allow the backlight through. Panel buffer boards usually also get 3.3v to run various digital logic chips.
The solid red arrows shows traces going to the SOC under the heatsink (pixel data) and traces towards the rectangular section (where LCD power supply is)
The dash red arrow is probably where the pin 35/36 trace points continue.. making their way towards the LCD panel power supply section.
Anyway, probably focus on finding the short in buffer board now.Last edited by howardc64; 04-13-2023, 11:47 AM.Leave a comment:
12 ohm is already low resistance and it's bad.Leave a comment:
I think the caps are actually good. I tested them originally in diode mode listening for a beep. Actual resistance is about 12 ohms. Maybe that's still bad, but there is no dead short.Leave a comment:
Look at those caps reading short real closely with magnification maybe, see if you see anything that looks like a fine line or such, if you do then carefully remove it and recheck it and the pads where it goes on the board, see if you still have a short.Leave a comment:
@Howardc64 - I tried checking all the caps on the buffer boards but no luck.Leave a comment:
See attached pic. I was trying to follow pins 35/36 on MB, but they disappear into the holes, and they aren't on the other side of the board. In my search, I found shorted caps (everything circled in orange) and a resistor? called R82 2029. Thoughts?Leave a comment:
Ok, so see the attached picture. Pin 37 doesn't matter. Pins 35 and 36 both need to be isolated to stop the loop. These pins go to the test points indicated in the picture. I'm hopeful that DT601, DT602 or IC601 is the culprit.
What are these chips and how should I troubleshoot further?
- Towards main board to see if can find labels for what they are
- I don't know if main board's t-con section will boot far enough without LVDS connected, but perhaps try that and read voltages on the masked off pins on the main board to get a clue.
- Follow the test pads on the buffer board further to see what they are connected to.
Can also just check all caps on buffer boards for shorts using mult-meter with beeping diode mode (+ - probe on both side of every cap). If beep continuously, then you've found the shorted rail. But still need to find the shorted component on the rail usually by various combination heat method (touch, isopropyl evaporation, FLIR, voltage injection)Leave a comment:
Bc1 - dt1042-04so (4 CHANNEL LOW CAPACITANCE TVS DIODE ARRAY)Attached FilesLeave a comment:
by torchzackHi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't... -
by eigmaHi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
Main board: BN94-07592P / BN97-08922R...1 Photo -
My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?... -
Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ? -
by THXFXHi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
I check capacitors and diodes and didn't find any short IN MAINBOARD.
Measured all power supply... - Loading...
