Samsung QN75Q60TAF Boot Loop fixed but no picture
+ More Options
Latest Activity
  • Nicktronic
    replied
    Re: Samsung QN75Q60TAF Boot Loop fixed but no picture
    Originally posted by lotas
    Check if these pins match (6 pin(clk) with 35pin and 7pin(hold) with 36pin)
    These pins can be passed through 47 ohm resistors.
    I've already confirmed pin 6 (clk) and i will confirm pin7 (hold) tonight
  • lotas
    replied
  • lotas
    replied
    This wiring diagram is correct, it is from this chassis (from this model).
  • Nicktronic
    replied
    Originally posted by Diah
    i think this statement of you wrong or the diagram belong to other chassis
    any way.. since now the NOR out of the circuit. please compare in Diode mode DT601 602 specialty the reading of Pins 1 & 3 for each against them self and to other pins . also at reserve probe. to make it easy each time to measure write down where are the + & -
    Ok, will do.
  • Diah
    replied
    Originally posted by Nicktronic
    Yes, it's actually pins 61 and 62. I counted from the wrong end of the connector originally. So 35=62 and 36=61. Sorry about that..
  • lotas
    replied
    4.68Kohm - 4.7 kOm.
  • Nicktronic
    replied
    They can be at 10kOm (pull-up to 3.3v), and at 47 Om they are through (6 lines, 6pin)
    Yes, they are 4.68Kohm, sorry, they are not open.
  • lotas
    replied
    Tested all resistors, see picture. Two open.....
  • Nicktronic
    replied
    Go ahead and test that resistor you mention there, see if the ohms are any or much different than the rest in that box there and maybe test some of the other similar resistors on other parts of the board, see what you get.
  • Nicktronic
    replied
    Wiring Diagram
    replied
  • Diah
    replied
    LOL nothings to argue,, they are 2 channel Horizontal and Vertical. because the LVDS Single. IC had 8 pins. 2 GND & VCC and 4pins for data 2 for each channel. left 2 SCLK and chip select they go to test point not for any of DT
  • lotas
    replied
    i don't think so... NO 6 SCLK had nothings to do with any protection
    output 0 and 1 yes each go to DT
    I will not argue, I tell it like it is.
  • Diah
    replied
  • Diah
    replied
    All of these 6 pins go through the protection diodes and out to the control points.
  • lotas
    replied
    Wiring Diagram
  • Nicktronic
    replied
    check pin 6 of ic where it go .. did it had contact at any lvds socket
    See picture. It goes through a 47.5 ohm resistor and directly to Pin 35.
  • lotas
    replied
  • Diah
    replied
    As requested...
    replied
    I grabbed the wrong data sheet, looks like it was for the 8 pin package not 6.
  • torchzack
    Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
    by torchzack
    Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
    I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
    Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
    08-28-2023, 07:42 AM
  • eigma
    Samsung UN40H5003 boot loop every ~8 seconds
    by eigma
    Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
    Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
    SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
    Main board: BN94-07592P / BN97-08922R...
    11-20-2024, 10:31 PM
  • signedupfordownload
    Samsung UE49KU6500U boot loop
    by signedupfordownload
    My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
    With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
    I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
    07-29-2024, 01:56 PM
  • arbitarytwist
    Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
    by arbitarytwist
    Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
    Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
    03-01-2025, 01:16 PM
  • THXFX
    samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
    by THXFX
    Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
    I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
    When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
    What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
    I check capacitors and diodes and didn't find any short IN MAINBOARD.
    Measured all power supply...
    03-20-2024, 03:21 AM
