where is the
  • MrKite59
    • Sep 2010
    where is the
    My mum has an LG LCD TV (model No 26LC2R-ZJ) which now steadfastly refuses to work
    After doing some internet research, I have come to the conclusion that the TV's capacitors have probably blown. - This, Apparently, being a common fault on this particular make & model of TV.
    The internet also states that removal & replacement of the capacitors, is quite easily achievable, (and less expensive) without reverting to professional expertise
    can anyone, who has, recently, done so, Please advise me where they are situated, & how to get at, remove & replace them, as I have no idea, Where the powerboard is
    Many thanks
  • PlainBill
    • Feb 2009
    • 7034
    Re: where is the
    Download the service manual and look it up for yourself.
    PlainBill
    • retiredcaps
      • Apr 2010
      • 9271
      Re: where is thepowerboard on LG26LC2R-ZJ
      1) Fixing this TV may not be as easy as one thinks especially if caps are not the problem. We can point out the power board easily.
      2) Post clear focused pictures AFTER reading
      https://www.badcaps.net/forum/showthread.php?t=1868
      Please do not post pictures inline as they slow down the loading of pages.
      For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
      Here is an example of the pictures we want.
      https://www.badcaps.net/forum/showpo...94&postcount=1
      --- begin sig file ---
      --- end sig file ---
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • bohaboha
        Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
        by bohaboha
        Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
        anyhow i couldn't t read anything else
        the backlight is on strong and the screen does not get dark or very dark but no pictures
        the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
        01-02-2025, 08:04 PM
      • valvashon
        LG 55UH6150- trouble powering up, then half lit screen (pictures!)
        by valvashon
        The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
        Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
        11-24-2024, 12:08 PM
      • 2elw
        SVOD4 PCB pictures + parts
        by 2elw
        Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
        STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
        GW1N-UV9UG169C6/I5 FPGA - Its a...
        07-04-2025, 12:23 PM
      • Nick Nougat
        Siemens Gigaset DA810A landline telephone with answering machine resets every minute
        by Nick Nougat
        I'm posting this here since there does not seem to be a more fitting category.
        The Device
        The Gigaset DA810A is a landline telephone with an LCD screen, an answering machine and integrated telephone book. I have the version for the European (i.e. German) market.
        It has two separate modules that can operate independently of each other: One is the basic telephony part that always works and is powered by the DC voltage coming through the telephone wire. It relies the TEA1110A telephone transmission and dialler chip for that.
        The 'smart' part of the phone with the answering...
        04-01-2024, 04:00 PM
