hisense 55K321UW help please
  • rotorwayrichard
    • Mar 2023
    • 6
    • South Africa
    hi guys , i am looking for assistance with my hisense 55K321UW , stuck on standby , ie light on , but pushing power button has no response , occasionally i can get it to power up and all is perfect until i switch it off again , then only standby light is active and nothing else , internal boards are RSAG7.820 6135 ROH for main board , RSAG7.820 6106 ROH power supply and T-CON is RSAG7.820 6125 ROH , if anyone can give me some directions please post and i will do my best to follow the instructions as well as i can , our local agents cannot supply parts as they say it is discontinued so i am a little jammed , it is around 6 and a half years old
    Any assistance will be greatly appreciated
    Rich
  • nomoresonys
    • 12332
    • U.S.
    Re: hisense 55K321UW help please
    Try a simple test, heat the electrolytic capacitors on the powerboard for a couple few minutes, then try the tv, see if it reacts any better for a bit.
    • rotorwayrichard
      • Mar 2023
      • 6
      • South Africa
      thank you for your response , i will give it a try and post results , cheers
      • nomoresonys
        • 12332
        • U.S.
        Can also look the solder joints on the bottom of the board over very closely and reflow any that look suspect, being careful not to bridge any, need to be careful what you touch the big caps can hold a charge for a quite while 400 volts CAN KILL, can check them with a multimeter, here's an article on the subject, I don't recommend using a screwdriver, when a resistor is simple to use and safer for the board: https://clevercreations.org/how-to-d...e-a-capacitor/
        • nomoresonys
          • 12332
          • U.S.
          Examples of bad solder joints there: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
          • jsdffxf
            • Mar 2023
            • 9
            • 美国
            What is the model of the master control? According to your description, the EMMC may be defective, which needs to be checked by the serial port tool
            • rotorwayrichard
              • Mar 2023
              • 6
              • South Africa
              thanks guys , i tried heating up the electrolytic caps on the power board but no change or response , i will take a closer look at the solder joints aswell on the board , frustrating as when i get it to power onn occasionally by the pulling the power cable , holding the power button down for 30 seconds etc etc , sometimes it powers right up and works flawlessly for hours until i switch ot off back to standby , then all i get is the standby light on again , i have noticed the mainboard processor heatsink being warm when testing it , not sure if that means much ,
              jsdffxf , master control ?? sorry i am still learning the lingo here ??
              • tomketcz
                schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ
                by tomketcz
                Does anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
                10-01-2025, 03:13 AM
              • Coolgoodman
                Faulty Hisense 85Q6NAU TV
                by Coolgoodman
                85” Hisense TV
                Greetings,
                Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                Dear TV technicians of forum, I hope this message finds you well.
                I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                07-24-2025, 03:02 AM
              • ShahZaib Ghumman
                Can I Swap Screens Between Two Hisense 75” QLED TVs?
                by ShahZaib Ghumman
                Hey folks,
                I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                03-25-2025, 10:59 PM
              • nono34
                Hisense stuck in Colors cycle like test pattern.
                by nono34
                I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                10-24-2024, 04:31 PM
              • rotorwayrichard
                by rotorwayrichard
                I have been waiting for a response from our local service centre and finally got a response from them yesterday , unfortunately the reply was that no parts are available due to the set being discontinued , hence me asking now on this site for the kindness of strangers
                My 6 odd year old set started not powering up more often than not , standby light on , but 9 times out of ten would do nothing, i tried the whole unplugging the set from the wall and holding the power button down routine and occasionally the set would boot up ok , once alive it worked flawlessly , every aspect worked no problem...
                03-12-2023, 04:03 AM
