ds-7208huhi-k1 bios bin
  • rt809h
    • Apr 2022
    • 5
    • UAE
    please help unlock this file
    Hikvision DS-7208huhi-k1
    part number ds-80294 _p rev1.1
  • BIOSSASI
    Creator 💀
    • Dec 2023
    • 35
    • SRILANKA
    Here is your file- UNLOCKED --- use admin1234 and pattern "Z"
    • min89444
      • Jun 2024
      • sohag
      password please
      • BIOSSASI
        Creator 💀
        • Dec 2023
        • 35
        • SRILANKA
        Originally posted by min89444
        password please
        password - admin1234
        if asking a pattern simply draw big "Z"
        enjoy
        • Oschly Pragmatyczny
          • Apr 2025
          • 4
          Writing this eeprom to my unit will unlock access to HDD content? Or content is somehow additional encrypted?
          • BIOSSASI
            Creator 💀
            • Dec 2023
            • 35
            • SRILANKA
            Writing this dump will not change anything in records section. Your hdd is encrypted with cpu.
            • BIOSSASI
              Creator 💀
              • Dec 2023
              • 35
              • SRILANKA
              You can access all settings and Recordings. It will not affect hdd data
                • Apr 2025
                • 4
                Thanks a lot for info. I will try your file then.
                • BIOSSASI
                  Creator 💀
                  • Dec 2023
                  • 35
                  • SRILANKA
                  Good Luck Brother 😊
                    • Apr 2025
                    • 4
                    EEPROM should have any specific markings?
                    • BIOSSASI
                      Creator 💀
                      • Dec 2023
                      • 35
                      • SRILANKA
                      No, the EEPROM itself doesn't need any specific markings. Just make sure the motherboard is marked 'DS-80294_P Rev1.1' as required.
                      • to5it0
                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                        by to5it0
                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                        I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                        This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                        I have opened the laptop and identified the main BIOS chip...
                        10-24-2025, 01:35 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • maanee11
                        Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                        by maanee11
                        Hello Everyone,
                        I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                        It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                        In the website, you can only see specs etc.
                        I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                        11-08-2025, 04:08 AM
                      • m1ch43lzm
                        Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                        by m1ch43lzm
                        Hi everyone
                        I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                        Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                        Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                        There's also an extra OTP Secu.R...
                        09-06-2025, 05:47 PM
                      • Forest79
                        by Forest79
                        However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                        07-23-2023, 07:39 AM
