Re: Tv Philips 47PFL3188H/12 (chassis tpn10.1e la) No led No power
Hi is the problem solved ?
But I don't even have the red standby ledLeave a comment:
I'm pretty sure the 3.6v is your stby voltage. I would try jumping the 3.6v to the on/off pin. I bet that the main board isn't sending signal to on/off pin to turn it on. I just had this issue on a Samsung. Ended up being the CPU on mainboardLeave a comment:
always better to follow first impressions, it's a motherboard problem, even with the new power supply it's the same, I'll try to repair that or look for a second-hand motherboardLeave a comment:
I found the power supply board at a good price, when it arrives I replace it completely hoping there are no problems on the motherboard tooLeave a comment:
maybe check all the transistors on the poerboard, they're labeled starting with Qxxx, make sure none of the 3 pins are shorted to either of the other 2 pins.Leave a comment:
see what voltage you get at the backlight connector, I think you measure from plus to minus.Leave a comment:
how is the bridge rectifier, the 2 outside are measured in vdc, the 2 inside are measured in vac.Leave a comment:
maybe check that cable, make sure you have continuity from end to end for pin 2, give it a wiggle too, in case it's broken somewhere.Last edited by nomoresonys; 03-09-2023, 03:30 PM.Leave a comment:
the voltage is there, honestly everything seems to be there, on the motherboard I detect all the voltages 12v, 5v 3.3vLeave a comment:
ok, go to the state where you are getting the 11.3, I think thats with everything connected right? then see what voltage you have at the the 2 big caps there, a probe on each leg, check them both.Leave a comment:
try unhook backlight cable at powerboard, plug powercord in, see if you get a led on front.Leave a comment:
oh, with everything hooked up as normal, try the flashlight test, shine it on an angle if needed, hit the menu button on tv, see if you can see any text or anything.Leave a comment:
I think this powerboard should be able to start alone but I don't know how it's done, maybe it did start and just can't seem to get the backlight on voltage to kick in for some reason. It's an interesting problem, prolly easy for some of these guys to figure out.Leave a comment:
Thinking its a mainboard issue, the ps-on is being sent but the on/off is not, can you trace that on/off signal back thru the mainboard?Leave a comment:
I will try nowLeave a comment:
ok, so looks like the only thing working is injecting 3 volts, so if you can maybe slip both pin 2 and 3 out of the cable connector and apply 3 volts to each, might need to apply voltage to dim also.Leave a comment:
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
by CurtisCHello everyone. I'm brand new to the group. I'm trying to fix this Philips 4K TV. I have minimal experience with most of this so forgive me if I don't understand half of what is posted on these forums. I'm trying to find my way through it.
Basically I got the TV from a previous owner who said it just died on them. So I wasn't there when it broke. It will not power on, no lights, no backlight, no sound.
The output of the power supply has a 27 pin connection to the main board. Pins 18-27 (labeled P-On+20v) are the only pins reading power at 12v each. The pins marked ALL+3.3v, which... - Loading...
