LG 49UJ6500 LCD panel lighter band that goes away
  • howardc64
    • Jun 2017
    • 492
    49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
    Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on the panel. Reseated both ends of the 2 T-Con flex, no change.
    Have seen similar on 2009-2011 Apple 27" LCD panels made by LG. Those will exhibit lighter band on left edge if not used for awhile. Goes away after awhile and don't come back as long as the i27" Mac/Thunderbolt display (these devices use this particular LG panel) is plugged in
    Anyone know what this is? on the Apple 27" LG LCDs, panel seems to want some current flow to get rid of this problem. Appears similar on this TV panel.
  • kasfamily
    • Aug 2014
    • 765
    • Russia
    Re: LG LCD panel lighter band that goes away
    Try to disconnect the harnesses going from the main to the matrix in turn. Will there be this stripe on each of the halves of the screen.
    • howardc64
      • Jun 2017
      • 492
      Looking at the screen
      Left side T-Con flex removed (white stickered flex)
      Right side T-Con flex removed (red stickered flex)
      When plug both T-Con flex back in, only right side shows band. Eventually becomes faint and disappears after few min.
      Looking closer at the band with magnifying glass shows its pixel color error. So maybe t-con section on the main board
      • Diah
        • Feb 2013
        • 6343
        its not easy to find the fault at MB T-CON circuit which caused this.
        but try heating with hair dryer several point at MB. or use pressure with finger at heat sink... and remark any change.
        or try to make carefully pressure on the Bezel corner where the issue appear.. see any change.
        • Davi.p
          • Sep 2009
          • 4267
          • Italy - Milan
          The fault is mostly on the panel's gate drivers, are them of COF type? Therefore side tabs?
          • howardc64
            • Jun 2017
            • 492
            Hair dryer heat sink area near T-Con connectors and turn-on TV. Perfect pixels at the top so definitely thermal related on main board.
            I'll try reflow next. Have pre-heater, good hot air station, no residue flux for BGA reflow and toaster oven (haha). Toaster oven has been the easiest in the past... less chance of over heating but I guess stresses the whole board.
            • howardc64
              • Jun 2017
              • 492
              Reflowed. Seems to make no difference. Hair dryer different parts of main with heatsink off, no difference.
              When remove both T-Con connector from main, sometime lines/band appear and repeatedly do this while power cycle. Sometimes no line/band appear and repeatedly do this while power cycling. Gently pressuring upper panel corner doesn't change top lines/band.
              Strange.
              • Davi.p
                • Sep 2009
                • 4267
                • Italy - Milan
                you must remove screen bezel as i have said..
                • howardc64
                  • Jun 2017
                  • 492
                  4K panel, no side COF tabs. Took off bezel
                  • Gently pressed upper corner and all along left and right edge.
                  • Pressed panel bottom COF tabs on panel and on driver board.
                  No difference.
                  Tried taping both T-Con flex connector in various locations. No fix.
                  • howardc64
                    • Jun 2017
                    • 492
                    Looked up Apple 27 LG LCD bright line problem since its common. A poster comment its from IPS overbias
                    https://www.ifixit.com/Answers/View/...ears+in+corner
                    This LG TV is IPS panel so decided to run the following youtube IPS panel exerciser
                    https://www.youtube.com/watch?v=BFUv...0jimbojones000
                    Stopped the video @ 20min. Solid bright colors would have brightness flicker afterwards (not my eye, wasn't looking at the test before turn it off) which eventually steadied. Turn off the TV for an hour and back on, lines are gone! Only changes are
                    Heat sink back on main board with 2 spring clips
                    Ran IPS video exerciser
                    Turn it off and back on after 20-30min. No more lines...
                    Put the rear TV panel back on, moved to different room. Lines are back.... But of course lines fade after running the TV for a few min. Perhaps I'll just leave it this way.
                    Strangest problem.
                    • howardc64
                      • Jun 2017
                      • 492
                      Think I finally found the failure and non failure mode. it is EXACTLY same as 2009-11 Apple 27" LG IPS screen failure mode.
                      If TV is plugged into the wall but powered off. After a couple of hours, no more lines on future power-on
                      If TV is unplugged for just a few min. Next power on will have lines.
                      This is similar to my Apple 27" IPS screen experience. I have seen many all with same behavior.
                      This behavior is the cause for confusion while diagnosing this problem. Power connection is constantly being unplugged during various disassemblies and test while chasing various suspected causes. I only discovered this after stopped assembly/disassembly/moving the TV which all required unplugging the PSU.
                      Anyway, don't know why but these LG IPS panels is either getting some power or avoid discharging completely with the TV plugged in but powered off.
                      • Davi.p
                        • Sep 2009
                        • 4267
                        • Italy - Milan
                        You are probably lucky, try replacing the electrolitic caps on main board, or if you have capacity/esr tester test them.. you can also try to leave tv unplugged for an hour, then heat those caps with hair dryer then turn on tv..
                        • howardc64
                          • Jun 2017
                          • 492
                          I previously did heating test without success. But can give it another try now I have clear solution to repair the lines. Have tested the solution a few times already.
                          Besides likely cause due to simply aging. Another possibility is the LG IPS panels might also get this problem by the slight bending when lifting the LCD panel out and reinstalling. The panel was carefully remove with suction cups and place it on a clean surface.
                          Besides about 5mm of lines across the top edge of the LG TV panel, I also noticed ~1 pixel horizontal line about 15mm long ~5cm below upper right corner. If my "bending" theory is correct, this is the corner I lifted slightly to confirm lines on panel rather than backlight system. All of these lines disappears after plugging TV into the wall for about 2 hours.
                          Its hard to verify this theory because panel removal is usually attempting to fix some display problem already such as backlight system. Therefore, its hard to confirm the problem was not there prior to removal and the unavoidable slight bending of the LCD panel during removal. In future efforts, I'll attempt to verify this.
                          • Davi.p
                            • Sep 2009
                            • 4267
                            • Italy - Milan
                            your words..
                            • howardc64
                              • Jun 2017
                              • 492
                              your words..
                              Yes, unfortunately later attempts didn't work (post #7). So its strange. This is before I discovered real problem+solution by plug into the wall. Maybe first hair dryer attempt waited long enough after plugging into the wall and the later attempts did not?
                              Also failure seems to depends on image color. Sometime it shows on dark image and sometimes no. Most times it shows on mid bright image. It disappear on too bright image.
                              Many variables. So far only definite solution is plug into wall for few hours If I just unplug for few min, lines will appear again.
                              • Davi.p
                                • Sep 2009
                                • 4267
                                • Italy - Milan
                                have you got a capacitor meter? the test is fast
                                • howardc64
                                  • Jun 2017
                                  • 492
                                  I think I will just keep current solution for now. The solution with leaving plugged in for couple of hours is common usage profile, problem never appear again until next unplug for another 2 hours. So I will stop chasing problem now
                                  • howardc64
                                    • Jun 2017
                                    • 492
                                    Re: LG 49UJ6500 LCD panel lighter band that goes away
                                    An interesting update. The light band seems to have gone away...
                                    After plugging the TV in for a week and using it (rarely and briefly). Unplugging it for 2x 24 hour cycles didn't result in band appearing at the top anymore.
                                    Interesting result. I guess something takes many hours to fully charge up or discharge haha.
                                    • triplefour
                                      SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                                      by triplefour
                                      TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                                      tcon is built into mainboard.
                                      Only one cable goes to panel boards.
                                      there is a cable from one panel board to the other that links them.
                                      cost cutting measure that results in us having harder time to diagnose.
                                      removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                                      used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                                      07-28-2022, 07:59 PM
                                    • Storyteller12
                                      QN55Q60R Service Menu Panel Help
                                      by Storyteller12
                                      I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                                      I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                                      I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                                      the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                                      01-13-2024, 01:57 PM
                                    • maneatingmonkey
                                      Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                      by maneatingmonkey
                                      I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                      There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                      03-27-2024, 07:17 AM
                                    • KYBOSH
                                      Samsung UN50TU8000 - Dead Panel Forensic Questions
                                      by KYBOSH
                                      I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                                      When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                                      When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                                      Later I checked for shorts on the panel PCB boards but could not find anything.
                                      When I took a look with the FLIR i noticed the 2 resistors...
                                      08-10-2024, 08:39 AM
                                    • NWArkGuy
                                      Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                                      by NWArkGuy
                                      Well, I will be the first to admit that I screwed up...
                                      In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                                      I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                                      I have 2 that I have found and have in my possession. ...
                                      10-12-2023, 10:13 PM
