Samsung ue32t5300ak
  • Moij
    • Jul 2019
    • 49
    • estonia
    #41
    Did I need connect power to the PCB/TV or all needed powers for EN25Q40B are coming from CH341A programmer?
    I know how to mod CH341A to work fully on 3.3V, so 3.3V must be not a problem.
    • lotas
      • Jan 2016
      • 5398
      • Russia
      #42
      There is no need to supply power, everything is powered through the programmer.
      • Moij
        • Jul 2019
        • 49
        • estonia
        #43
        OK, I ordered CH341A and will first test writing EN25Q40B without soldering it out.
        But on TV LED is blinking 1 long, 5 times short in cycle and as I understand no LED blink codes are available for that TV model and error can be also somewhere else than IC401 memory content fault.
        • Moij
          • Jul 2019
          • 49
          • estonia
          #44
          I also checked voltages on board. 3,3V is present, 13V is present, 1,8V CPU power is present, but 5V USB power is missing and also back LED 43V is missing. Can faulty EN25Q40B content cause missing USB and back LED voltages?
          • lotas
            • Jan 2016
            • 5398
            • Russia
            #45
            The processor power supply cannot be 1.8v; it should generally be 0.9-1.0v. Due to damage to the standby firmware, the TV will not start and there will be no main power supply for operating mode...
            • Moij
              • Jul 2019
              • 49
              • estonia
              #46
              It can by that 1.8 V is not CPU power, it was closest to CPU marked voltage pin on PCB without removing CPU heat sink.
              So is it normal that USB 5V and back light LED 43V are missing when TV is not in operating mode and most probably problem is IC401 information damage and can be fixed with writing new firmware to it?
              • Moij
                • Jul 2019
                • 49
                • estonia
                #47
                I find one more thing what can indicate what problem I have with bn91-21809k board. When after power on indication led is blinking 1 long, 5 short blinks, seems like actually TV is not in standby mode as main CPU heat sink temperature rises within 20 minutes to 38 C degrees. I understand in standby mode main CPU must not have power, or I am wrong?
                • cheeky2
                  • Dec 2012
                  • 361
                  • uk
                  #48
                  Looks like you have other issues than the firmware corruption as if you read the first post you will see that the standby led flickers when the remote control is pressed. If that is not the issue then you have incorrectly diagnosed your issue with your TV. As you have ordered the ch341A programmer than you can always try to see if it resolves your issue. I would suggest you read the flash ic first to see if the data is corrupted. Good luck
                  • Moij
                    • Jul 2019
                    • 49
                    • estonia
                    #49
                    I get CH341A programmer, version what works fully on 3,3V, no modification needed, I checked this with multimeter and this is thru. I used Neoprogrammer software, installed WUDF driver, programmer was recognized by PC as USB-EPP IC CH341A. I get also adapter with spring loaded contact header. But when I connect adapter to EN25Q40 without desoldering it (no power was connected on TV) then PC and also Neoprogrammer software lost CH341A programmer connection. I measured supply voltage on EN25Q40 when CH341A was connected, it was 3.2 V. PC was on battery power.
                    What this mean, is EN25Q40 physically corrupted?
                    • lotas
                      • Jan 2016
                      • 5398
                      • Russia
                      #50
                      The USB cable must be of high quality (thick, short) to avoid losses. I don't see how you connected it to the programmer. The clip, as always, may have poor contact with the chip. Personally, I never use it; I always have problems.
                      Take a photo of how you connected everything.
                      • Moij
                        • Jul 2019
                        • 49
                        • estonia
                        #51
                        CH341A was directly in laptop PC USB port. I double checked all polarities and connection, all must be right.
                        • Moij
                          • Jul 2019
                          • 49
                          • estonia
                          #52
                          Image of connection, blue wire is pin 1 on EN25Q40
                          • lotas
                            • Jan 2016
                            • 5398
                            • Russia
                            #53
                            And the rest of the colors of the wires match the numbering of the pins, otherwise it is not visible because of the white cap.
                            • Moij
                              • Jul 2019
                              • 49
                              • estonia
                              #54
                              Yes, wires match on both ends correctly with pins numbering/location.
                              More details can be seen https://www.aliexpress.com/item/1005...av-description
                              There is cavity in the tip acrylic part for chip case and pins with springs touches exactly chip pins.
                              • lotas
                                • Jan 2016
                                • 5398
                                • Russia
                                #55
                                Well, I don't know then, there is also a 25Q80 chip on the board, try it with it (just be careful! read the dump), maybe the programmer is faulty, maybe it doesn't supply power, maybe the signal lines to the processor are preventing the connection, or unsolder it and use an adapter to read the contents and check.
                                • Moij
                                  • Jul 2019
                                  • 49
                                  • estonia
                                  #56
                                  I not find 25Q80 on PCB, closest to this is 24512FD labeled I2C EEPROM, not SPI.
                                  • lotas
                                    • Jan 2016
                                    • 5398
                                    • Russia
                                    #57
                                    Yes, I was mistaken, there is no 25Q80 on this platform.
                                    • Moij
                                      • Jul 2019
                                      • 49
                                      • estonia
                                      #58
                                      I measured IC401 EN25Q40 supply pin to ground with LCR meter, I get C is 35 uF with ESR 5 ohm, pure R is 5 ohm. For me it is nearly OK only ESR is very high but this 5 ohm can be in series on supply line.
                                      I also checked again CH341 programmer, it is 3,3V version, chip on it is actually CH341B and its supply is 3,3V also SPI TXD and RXD levels. It is confirmed here: https://www.eevblog.com/forum/repair...29/#msg5716029
                                      I find CH341B pin 25 is not properly soldered on programmer. Is possible that this cause problem I have with reading? Pin description is: MEM mode: write strobe output WR#, active low/ EPP mode: write operation instruction, low level write, hing level read. On CH341A programmer schematic what is available, is pin 25 not used.
                                      • Moij
                                        • Jul 2019
                                        • 49
                                        • estonia
                                        #59
                                        I modified my CH341B programmer, added 20 uF capacitor to supply and get it more operating. But still not get read memory correctly.
                                        First detection of IC not work, and SPI ID is like random, every read give different result, same for memory content.
                                        What I made wrong? Or this mean EN25Q40 is dead?
                                        • lotas
                                          • Jan 2016
                                          • 5398
                                          • Russia
                                          #60
                                          How can we say for sure that the SPI flash is faulty? To confirm this, you need to desolder it from the board and test it directly using the adapter (SOP to DIP). Reading and writing to the board always causes problems: sometimes the dump isn't read correctly, sometimes it's impossible to write.
                                          • Boardview and Schematic Bot
                                            Samsung Galaxy Tab S / E SM-T805W SM-T800 SM-T378V SM-T805W Schematic & Boardview
                                            Samsung Galaxy Tab S / E SM-T805W SM-T800 SM-T378V SM-T805W Schematic & Board View
                                            Samsung Galaxy Tab S 10.5 SM-T805W.sch.pdf
                                            Samsung Galaxy Tab S 10.5 SM-T800.pdf
                                            Samsung Galaxy Tab E 8.0 SM-T378V.pdf
                                            Samsung Galaxy Tab S 10.5 SM-T805W.bv.pdf...
                                            09-29-2026, 10:33 AM
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
