What program did you use?
NeoProgrammer V2.2.0.10 ?
Did you program the chip through a clothespin or solder the chip through an adapter?
Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
Nothing to do....
Standby led turns on and immediately off, sometimes led bars turns on and off imediatelyLeave a comment:
Attached FilesLeave a comment:
Hi lotas,
can you help me with this firmware???
Samsung UE55MU6400U
M/B BN41-02568B (BM94-12401R)
What initially happened to the TV? In service mode, at the point you clicked on “Micom Update” and after that the TV stopped turning on?
If yes, then the firmware has been erased in micom, you need to program it.
And also, you have some strange dump 24C512, or it is so badly damaged or poorly read, try this one.Last edited by lotas; 08-19-2024, 11:33 AM.Leave a comment:
Where did you get the idea that the problem is in these firmwares, if there is no standby mode and the LED is not on, then a common problem in this chassis is IC204 (stabilizer from 5v to 3.3v) and micom Weltrend, check the resistance at 1.2 pin IC203 relative ground and is there 3.3v power on these pins
I measured the regulator and i/p 5.3 v & o/p 3.3 v so it is good, also the voltage at pin 1&2 3.3v and no short with ground. i tried to press the reset button but nothing happened
how can i check ic1203 (61P805) is healthy ??
does it need programing? if yes can it be done by CH341?
Where did you get the idea that the problem is in these firmwares, if there is no standby mode and the LED is not on, then a common problem in this chassis is IC204 (stabilizer from 5v to 3.3v) and micom Weltrend, check the resistance at 1.2 pin IC203 relative ground and is there 3.3v power on these pinsLeave a comment:
Dear Sir can you help me with dead main board ( BN41-01587) for Samsung ua40d6400un and power board (BN44-0427A)
i uploaded the flash files from 24c02 (IC 1205) & 24c512 (IC 1401)
A5 & 3.3 vdc are exist.
thanks in advance.Attached FilesLeave a comment:
Hi Lotas, my TV model is UN50MU6100GCZB, Board Code: BN41-02568B from Argentina. I'm having the same issue as another user before. The standby LED turns on for 1 sec every 15 sec. When Flashing an incorrect bin, the board stays completely dead. So I guess it could be bios related. could you help me? Thanks in advanceAttached FilesLeave a comment:
Hi Lotas UE55MU6172 IC401 can you fix please.
Regards,
Pat.Attached FilesLeave a comment:
The TV does not turn on, there is no standby mode! SAMSUNG UE55mu6192 ver01Attached FilesLeave a comment:
Hi Lotas,
I tried with the fix file but the TV set is dead. The standby LED turns on for 1 sec every 15 sec. The standby voltage from 8v goes to 13v. At first, the TV was totally dead. Now it looks like there is some life in it but there must be a hardware problem in the mainboard.
Anyway, I want to thank you for your effort and time. I wish you the best. Thank you.Leave a comment:
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by totofCould you help me...
I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
Then motherboard connected, standby led is on and current consuption is 18W.
Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
The model of my TV is :
Power supply BN44-00807A
Main Board BN41-02568B / BN94-12765W
Panel CY-GM055HGLV3H... -
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by jeangonbayCould you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
The model of my TV is UE43MU6105K
Main Board: BN41-02568B
BN94-12007Y
Could you help me to repair the dump please. Thank you.
... - Loading...
