Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    replied
    Originally posted by Mr.Pc
    What is written on the paper is BN94-12811S. Model: BN41-02568 - Code: BN41-02568B is printed on the motherboard. If you want I can take a photo of everything
    What is the panel number? CY-GK065HGNVBH ?
  • Mr.Pc
    replied
    Originally posted by lotas
    What model, panel number, I want to check 25Q80 if I find a dump, and what is the motherboard number BN94-xxxxx?, it is written on a paper sticker on the motherboard.​
  • lotas
    replied
  • Mr.Pc
    replied
    How many times does the standby LED blink between pauses?
    It blinks non-stop, without pause, there is no error code. Measuring the voltage on the main PCB connector, the power supply oscillates between 11.5v and 9v. I did the test without the 25q40 and the voltage stabilizes at 9.5v. When I disconnect the power supply cable, the panel LEDs light up normally and the source voltage stabilizes at 12.65v.
    I did the test with a bench source too, I injected 12v into the main PCB and there is very low consumption and it goes back to zero, this keeps looping
  • lotas
    replied
  • Mr.Pc
    replied
    One at a time, and you will see which half of the panel is not working, if the problem is in the panel.
    I made the jumper and tested one side at a time, but it still didn't work. In any case, I am grateful for your dedication.
  • lotas
    replied
    So I make a jumper between the two, connect the LVDS cables and turn on the TV?
  • Mr.Pc
    replied
    These ones.
  • lotas
    replied
    These ones.
  • Mr.Pc
    replied
    Post a high-quality photo in the area of ​​the lvds connectors.
    I managed to find the points you mentioned, but I don't know how to identify them like that on the PCB. My camera isn't the best, but I believe I can see it. I marked a red dot in each place. I also want to thank you for your time and attention.
  • lotas
    replied
    Not yet because I don't know how to identify these points. What I did was disconnect the lvds cables and turn on the TV without them. 😅
  • Mr.Pc
    replied
    Did you place a jumper on the motherboard between contacts FB_TRDY_1 and FB_TRDY_3 (feedback)?
  • lotas
    replied
    I disconnected the lvds cables
  • Mr.Pc
    replied
    There is a negative voltage (VGL) on the T-CON, so one inductor should be connected to ground with one terminal, to convert the negative voltage relative to the ground, rather this is this inductor, check how it is connected.
    I have already checked your connection and everything is normal considering this negative voltage. I've already checked the USB and HDMI and there is no short. I also checked two mosfets that are in the connector that comes from the power supply and there are no shorts, which is why I was doubting the 25q40.
  • lotas
    replied
    I disconnected the lvds cables and it remains the same. I noticed that when I plug in the power supply, the voltage fluctuates as if there was a short on the main board. I found an inductor L406_UT on the main board that has a very low resistance of 0.04ohms. I don't have the schematics so I don't know if it's right.
  • Mr.Pc
    replied
    25Q40 is working, have you disconnected the lvds cable from the motherboard? (in this case how TV behaves)
  • lotas
    replied
    Hey guys! I also have my Samsung TV UN65MU6100G whith main pcb model/code: BN41-02568B and power supply: BN44-00808D which is not turning on and only has the standby LED blinking. I opened the TV and did some tests with the source board and the LEDs light up and the voltage is stable. It has two eproms and I believe the problem is in one of them. Could anyone help me with this, I extracted the file from both. Thank you in advance for everyone's attention!
  • Mr.Pc
    replied
  • Me_you_them
    replied
    Maybe I found the problem...
    I noticed that the component indicated in the photo it's no longer there,​ probably has blown out during the desoldering of the chip.
    Is there any solution?
  • Me_you_them
    replied
    What program did you use?
    NeoProgrammer V2.2.0.10 ?
    Did you program the chip through a clothespin or solder the chip through an adapter?​
    I've used NeoProgrammer V2.2.0.10 and I've desoldered the chip from the mainboard and soldered on the adapter to program it
    09-07-2024, 05:50 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • totof
    Samsung UE55MU6102K IC1604 dump needed - TV don't start
    by totof
    Could you help me...
    I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
    Then motherboard connected, standby led is on and current consuption is 18W.
    Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
    Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
    The model of my TV is :
    Power supply BN44-00807A
    Main Board BN41-02568B / BN94-12765W
    Panel CY-GM055HGLV3H...
    05-01-2023, 04:30 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • jeangonbay
    Samsung UE43MU6105K IC1604 dump needed - TV don't start
    by jeangonbay
    Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
    The model of my TV is UE43MU6105K
    Main Board: BN41-02568B
    BN94-12007Y
    Could you help me to repair the dump please. Thank you.
    02-16-2024, 05:46 AM
