Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    replied
    Originally posted by Mr.Pc
    I can yes!
    Why do you choose "Auto 25...", this is not the 25th series (spi flash). and 24 series (eeprom), you need to manually enter 24C512 and press "Select".
  • Mr.Pc
    replied
    Originally posted by lotas
    And how do you read it, like an eeprom or like a spi flash 25q40, you can post a photo of the eeprom itself and the programmer log, what it writes.
    I can yes!
  • lotas
    replied
  • Mr.Pc
    replied
    Circuit diagrams for new models, starting with the “D” series, cannot be found even in service centers, since they do not repair boards, but replace them entirely. Why can’t you read eeprom 24c512, did you unsolder it and read it through an adapter?
    Thanks for the explanation regarding the schematic. Regarding reading the eeprom, I unsoldered it and put it in my adapter, which is also soldered to the eeprom, but it didn't recognize it, so I believe it is bad. An interesting detail is that it doesn't have a pin 1 indicator (only on the motherboard it does) and I also didn't understand why pin 1-4 is on gnd on the motherboard, I looked at the datasheet to try to understand better but it didn't work. Anyway, I imagine that if this eeprom is bad, I won't be able to solve it because of the software that I can't read.
  • lotas
    replied
  • Mr.Pc
    replied
    Maybe it's still 24512FD, if so, then it's 24C512 and on the board 1-4 pins are connected together and sit on the ground.
    You write that your 5v is stable, but below is not stable, while 3.3v is doing well, they should also be stable, since this voltage powers the standby and the spi flash 25Q40 (8pin) should be stable at 3.3v.
    Hi Lotas! Me here again. Analyzing the 3.3v voltage it is also oscillating and then I realized that when removing the inductor from the 3.3v dc/dc regulator (this regulator receives 13v from the source board), after removing the inductor, the 13v from the source board stabilizes, however, As I said, I didn't find any type of short or apparent leak. I also checked if the 3.3v regulator heats up beyond normal, but it doesn't heat up at all. Don't you have the schematic for that board? Now I tried to read the 24512FD (it has pins 1-4 connected to gnd) but it gave an error and I couldn't read it.
  • lotas
    replied
  • Mr.Pc
    replied
    24C512 I can't check, since they are all different for each TV (it contains the model, settings, serial numbers, MAC Address, ....), I can upload a working dump for checking, just be sure to save your own one.
    Have you checked the wi-fi module or turned it off?
    Try.
    Hi Lotas! I've already turned off the Wi-Fi module too, but it stays the same, unless this card only works with the module connected, but I don't think so. I have the board here on the bench, I connected 13v and checked that even the 5v voltage is stable, below it everything fluctuates. I looked for the 25C512 but I didn't find it, I only found a 25512FD but I'm sure it's another component because on the board it has terminals 1 to 4 on the same track, so it can't be 25C512. Finally my head is starting to smoke and I'm already wanting to set everything on fire hahaha I think I'll try to look at another board because I don't have an oscilloscope to be able to see the circuit in another way, I also don't want to take up as much of your time as I already did . Thank you once again for all your support and patience.
  • lotas
    replied
    Try.
  • Mr.Pc
    replied
    So with 25Q40 and 25Q80 you have everything in order, all that remains is eeprom 24C512, dc/dc converters on the motherboard (the correct ones output voltages), underestimated or short circuit on the supply lines or the processor itself....
    Right! Can you verify 24512? I understand very little about programming and I'm even curious to understand it better, but as I said, if you can see it for me, I can read it and put it here. Regarding shorts, I didn't find any and the dc/dc ldo regulators I can't check the outputs because the board goes into protection and also doesn't have their reference so I can inject voltage and do the tests. Anyway, I'm still grateful.
  • lotas
    replied
  • lotas
    replied
    Pronto!
    Everything is correct, as it should be.
  • Mr.Pc
    replied
    Yes, this is not an error log, but a protection (status register), read the 25Q40 chip again and after reading, click on “status register” and a new window will pop up, this window show me where the checkboxes are...
    Pronto!
  • Mr.Pc
    replied
    Ok! I will make this now. Wait a minute.
  • lotas
    replied
    hmmm now I understand Lotas! About this error log issue, I don't know how to check. The TV's standby LED blinks continuously and does not report any code. To extract the file I use the TL866 II and I don't know how to see this error log with this equipment. 😅☹
  • Mr.Pc
    replied
    You don’t understand me, I don’t need dumps, but what status register is registered on 25Q40, which is what the programmer log shows when reading these statuses.
  • lotas
    replied
    I can yes! Just to let you know that since I read them the defect is the same. These are the same ones I already sent you, but if you want I can read them again and send them, but as I already told you the problem has been the same since then.
  • Mr.Pc
    replied
    Everything is fine with 25Q80 too, you can read dump 25Q40 again and show what its status registers are.​
  • lotas
    replied
  • Mr.Pc
    replied
    What is the panel number? CY-GK065HGNVBH ?
    Hello Lotas! Sorry for the delay, but it was due to the time. I picked up the TV again and saw the panel number: CY-GK065HGNV5G
    09-07-2024, 05:50 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    Today, 05:12 AM
  • totof
    Samsung UE55MU6102K IC1604 dump needed - TV don't start
    by totof
    Could you help me...
    I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
    Then motherboard connected, standby led is on and current consuption is 18W.
    Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
    Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
    The model of my TV is :
    Power supply BN44-00807A
    Main Board BN41-02568B / BN94-12765W
    Panel CY-GM055HGLV3H...
    05-01-2023, 04:30 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • jeangonbay
    Samsung UE43MU6105K IC1604 dump needed - TV don't start
    by jeangonbay
    Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
    The model of my TV is UE43MU6105K
    Main Board: BN41-02568B
    BN94-12007Y
    Could you help me to repair the dump please. Thank you.
    02-16-2024, 05:46 AM
