Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • zmeutul
    replied
    Originally posted by lotas
    Done, try it, don’t forget about status register (0x88, 0x42).
    Perfect. The TV works. Thank you very much.
  • lotas
    replied
    Originally posted by zmeutul
    Hello. I also have a samsung ue65mu6172 with the bn41-02568b motherboard that doesn't turn on and doesn't have the standby LED. From what I saw in the hex of the W25Q40CL chip, it seems to be corrupted at first. Can you help me with its repair? Thank you very much!
  • zmeutul
    replied
  • lotas
    replied
    Originally posted by pepebmx
    Hi, I have a Samsung TV model UN43MU6100GCZB (mainboard BN41-02568B BN41-02568). It first had random HDMI issues, then progressed to turning on with backlight but shutting off after a few seconds. All main power rails are present. Could you please check this dump? I suspect its the main problem. Thanks a lot!
    Hi, your dump is fine, working, the problem is different.
  • pepebmx
    replied
  • yureyko
    replied
    My dear lotas,
    I ordered the Winbond W25Q40BVSNIG and W25Q40CLNIG chips to check if there will be any difference.
  • Diah
    replied
    [QUOTE=lotas;n3596169]
    Don't make me laugh, where did spi flash get the I²C Protocol from, it's not eeprom.
    https://www.fs-pcba.com/ru/spi-vs-i2c/[/QUOTE
    then start to laugh lotas, script written as befehl which SoC do it as I2C act via eMMC / NAND firmware , when position of script address at SPI or eEPROM different the SoC will take order but it cant deliver it to Main Firmware.. this called Step BY Step start..
  • lotas
    replied
    Originally posted by Diah
    W25Q40BVSNIG have difrent clock signal at I2C will not take effect as the CL
  • Diah
    replied
  • lotas
    replied
    I haven't tried it, try replacing it with this one.
  • yureyko
    replied
    I desolder the SPI chip and clamp it with a clip. I haven't had issues with this before.
    Will the Winbond W25Q40BVSNIG chip work?
  • lotas
    replied
    Do you use it through a clamp or do you unsolder the flash and use an adapter on the programmer?
    Try another flash...
  • yureyko
    replied
    I was experimenting with everything back then... Now all the settings are correct.
  • lotas
    replied
    Originally posted by yureyko
    I tried your firmware, but I have the same problem. I have a black CH341A.
    When I try your other firmware for different TV models, I still have the same problem. It's probably an issue with the programmer or the SPI chip.
    And in the settings it is set as green.
  • yureyko
    replied
    Try this dump.
    And is your CH341A black or green?
  • yureyko
    replied
    Try to remove protection first, i.e. remove all checkboxes and press "Write", then erase and write dump again, then set the status register again...
    The same behavior in three programs (SiberiaProg, Colibri, NeoProgrammer).
  • lotas
    replied
    Try this dump.
  • yureyko
    replied
    The same result, it immediately enables that parameter.
  • lotas
    replied
  • yureyko
    replied
    Maybe I have a problem with the SPI chip or the CH314A programmer. Mine is not modified. Do I necessarily need to modify it?
    09-07-2024, 05:50 AM
  • totof
    Samsung UE55MU6102K IC1604 dump needed - TV don't start
    by totof
    Could you help me...
    I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
    Then motherboard connected, standby led is on and current consuption is 18W.
    Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
    Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
    The model of my TV is :
    Power supply BN44-00807A
    Main Board BN41-02568B / BN94-12765W
    Panel CY-GM055HGLV3H...
    05-01-2023, 04:30 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • jeangonbay
    Samsung UE43MU6105K IC1604 dump needed - TV don't start
    by jeangonbay
    Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
    The model of my TV is UE43MU6105K
    Main Board: BN41-02568B
    BN94-12007Y
    Could you help me to repair the dump please. Thank you.
    02-16-2024, 05:46 AM
    09-06-2024, 11:40 PM
