Samsung un75TU8000 backlight
  • yankys
    yanky
    • Feb 2012
    • 139
    I have a question I just picked up this TV and the back lights are needing replacing they flicker off and on does anyone know or have a video somewhere showing how to remove the screen to replace the back lights on this model any help would be greatly appreciate it thanks everyone
  • alfatv
    • Sep 2020
    • 353
    Re: Samsung un75TU8000 backlight
    Make sure it's actually a backlight problem.
    Disconnect the cable to main board and see if backlight is still flickering.
    • yankys
      yanky
      • Feb 2012
      • 139
      Ok I’ll try this.
        • 12276
        • U.S.
        see if that helps, it is good to try to verify the problem before tearing into that BIG screen, the bigger they are the easier they are to break, I don't like using suction cups, some do: https://www.youtube.com/watch?v=KvI7nMP2_M0
        • yankys
          yanky
          • Feb 2012
          • 139
          I unplug the main board and still flashing LEDs and there’s also dark spots where the LEDs aren’t lighting up when they flash, Thank you for the video but that’s not the same 78 like I have there’s no bezel screws on this one.
          • yankys
            yanky
            • Feb 2012
            • 139
            I’m sorry 79” not 78
            • yankys
              yanky
              • Feb 2012
              • 139
              I'm sorry again 70 inch not 78
                • 12276
                • U.S.
                I see, ok guess that one is for different model 75, put your exact model in youtube, might find one.
                • yankys
                  yanky
                  • Feb 2012
                  • 139
                  I posted the model wrong it is UN75AU800F
                  • yankys
                    yanky
                    • Feb 2012
                    • 139
                    Re: Samsung un75Au800F backlight
                    • yankys
                      yanky
                      • Feb 2012
                      • 139
                      • Storyteller12
                        • Jun 2020
                        • 625
                        This is QLED tv correct? I believe it’s thin boarder where screen goes edge to edge. If so it’s glued down and will need to be very careful taking it out. Other than that it’s just like any other tv.
                        If you have never removed a panel before I don’t recommend this for your 1st one being as big as it is.
                        • yankys
                          yanky
                          • Feb 2012
                          • 139
                          Yeah I believe it is a QLED I’ve replaced some back lights before just makes me a little nervous with the glued in the screen.
                          • yankys
                            yanky
                            • Feb 2012
                            • 139
                            I
                            It was the backlights replaced them now it working and the screen is held in by the bezel it snaps on to the fame once you remove it the screen will lift out together.
                              • 12276
                              • U.S.
                              Very nice work, what technique did you use to remove the screen?
                              • yankys
                                yanky
                                • Feb 2012
                                • 139
                                I used a small screw driver and carefully releasing the bezel, one side then top and other side then clips on bottom once the cables are removed for the screen tape them to the screen I used suction cups with just enough pressure to hold screen don’t squeeze to tight on suction cups. Or you will damage it then just lift and screen comes out with bezel on this model. After this goes just like any other edge lit tv, hope the helps others.
                                • Storyteller12
                                  • Jun 2020
                                  • 625
                                  Nice!!!! Glad you got it fixed and working. Good job
                                  • yankys
                                    yanky
                                    • Feb 2012
                                    • 139
                                    Thank you everybody on here is been a great help I appreciate it I’m sure I’ll need more in the future lol.
                                      09-07-2024, 05:50 AM
                                    • sansanpartida
                                      Samsung QE82Q70RAT no backlight
                                      by sansanpartida
                                      Hi everyone!
                                      Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                      My issue: No backlight.
                                      Model: QE82Q70RAT
                                      Type No: QE82Q70RAT
                                      The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                      So hopefully, I can fix this cheaper.
                                      05-22-2024, 06:56 AM
                                    • howardc64
                                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                      by howardc64
                                      • Prior owner tried a replacement main board. No difference.
                                      • Samsung 2x red blinking standby LED = panel fault
                                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                      07-19-2025, 10:54 PM
                                    • Warrensmith
                                      Samsung BN44-00807E Low Backlight
                                      by Warrensmith
                                      Symptom is dim backlight - this set came in with almost no backlight.
                                      Samsung UN55JU6500FX2A
                                      1 - Replaced all backlight LED strips (set had lots of hours at level 20 backlight)
                                      2 - Changed out what appeared to be a bad Q9102C on BN44-00807E - not shorted or burned but appeared to be open. I was able to read (with difficulty) the part number - however I may have misread it - Can someone confirm that this is indeed an AOD9N40.
                                      Backlight improved significantly - about like it would be set to a level 3 or 4. Setting all the way to 20 seems to...
                                      10-27-2022, 07:09 AM
                                      09-06-2024, 11:40 PM
