Samsung un75TU8000 backlight
    I have a question I just picked up this TV and the back lights are needing replacing they flicker off and on does anyone know or have a video somewhere showing how to remove the screen to replace the back lights on this model any help would be greatly appreciate it thanks everyone
    Re: Samsung un75TU8000 backlight
    Make sure it's actually a backlight problem.
    Disconnect the cable to main board and see if backlight is still flickering.
      Ok I’ll try this.
        see if that helps, it is good to try to verify the problem before tearing into that BIG screen, the bigger they are the easier they are to break, I don't like using suction cups, some do: https://www.youtube.com/watch?v=KvI7nMP2_M0
          I unplug the main board and still flashing LEDs and there’s also dark spots where the LEDs aren’t lighting up when they flash, Thank you for the video but that’s not the same 78 like I have there’s no bezel screws on this one.
            I’m sorry 79” not 78
              I'm sorry again 70 inch not 78
                I see, ok guess that one is for different model 75, put your exact model in youtube, might find one.
                  I posted the model wrong it is UN75AU800F
                    Re: Samsung un75Au800F backlight
                        This is QLED tv correct? I believe it’s thin boarder where screen goes edge to edge. If so it’s glued down and will need to be very careful taking it out. Other than that it’s just like any other tv.
                        If you have never removed a panel before I don’t recommend this for your 1st one being as big as it is.
                          Yeah I believe it is a QLED I’ve replaced some back lights before just makes me a little nervous with the glued in the screen.
                            I
                            It was the backlights replaced them now it working and the screen is held in by the bezel it snaps on to the fame once you remove it the screen will lift out together.
                              Very nice work, what technique did you use to remove the screen?
                                I used a small screw driver and carefully releasing the bezel, one side then top and other side then clips on bottom once the cables are removed for the screen tape them to the screen I used suction cups with just enough pressure to hold screen don’t squeeze to tight on suction cups. Or you will damage it then just lift and screen comes out with bezel on this model. After this goes just like any other edge lit tv, hope the helps others.
                                  Nice!!!! Glad you got it fixed and working. Good job
                                    Thank you everybody on here is been a great help I appreciate it I’m sure I’ll need more in the future lol.
