LG Nano91 TV Backlights
  • Diah
    • Feb 2013
    • 6614
    Re: LG Nano91 TV Backlights
    Originally posted by Storyteller12
    Ill have to measure with dmm later as I'm not at the office now but I don't think it measure open as the led lights up but only show 9v on tester
    also dont forget to messure the size of it with mm.
    • Storyteller12
      • Jun 2020
      • 625
      Originally posted by Diah
      i think they are just normal LED from innotek 6.4V
      You may be right. I have 6v led to put in and test but why would these measure 9v even when off the strip if there 6.4v?
      I can remove a good led to test but I'm almost positive it will show 20v
      • Diah
        • Feb 2013
        • 6614
        They split down the middle into separate strips. But effectively it’s 8 strips 16leds.
        i know same system with hisense nano.. i do believe 99.9% normal innotek led 6,4v almost size 3040
        by the way.. the one you took it out just take look on the back side.. you will see only 2 pool
        • Diah
          • Feb 2013
          • 6614
          dear friend... believe me and dont bleieve your tester.. LED tester good only^with normal LEDs with out ziner diode build in.
          • Storyteller12
            • Jun 2020
            • 625
            I believe you. Thanks for the help. I will report back with my finding tomorrow
            • lotas
              • Jan 2016
              • 4900
              • Russia
              #26
              Here ziner diodes are installed separately on the bar for each channel (4 leds).
              • Diah
                • Feb 2013
                • 6614
                lotas innotek build the ziner inside the led unit.
                • Storyteller12
                  • Jun 2020
                  • 625
                  Diah,
                  Measured the led in beep mode and diode mode and got OL on both. No shorts but no reading either. As for size I cannot measure but I took a pic of it next to a 3030 led for comparison.
                  • Diah
                    • Feb 2013
                    • 6614
                    Diah,
                    what about the back side of it can we see it .. ?
                    can you zoom on the front surface to see how many small dark dots it had..
                    by the way... the type info of the LED should be print at the strips lable
                    • Storyteller12
                      • Jun 2020
                      • 625
                      Here you go
                      • Diah
                        • Feb 2013
                        • 6614
                        from the photo i can see there are 4 LEDs section. 4x6 =24V or coulf be they are just 3 x6= 18V. on the label there are 18UM 2W
                        you need to see the back side exactly if they are separated ( no conection at bed )to know how many they are, same as Lotas said early they are group of many LEDs
                        • Storyteller12
                          • Jun 2020
                          • 625
                          I tried my best to desolder and take a pic of it. It's so small and I don't have a scope so it's hard to work on.
                          The last pic I believe is the best and I think your right about 4leds.
                          Now we have some better info on them. Trying to source them is another thing
                          • Diah
                            • Feb 2013
                            • 6614
                            yours last photo they look 8 leds... and you do have 8 channel.. lol
                            the best way look on the strips where you removed the led..
                            • Storyteller12
                              • Jun 2020
                              • 625
                              It's still hard to tell. But here is the strip where it was removed from
                              • Diah
                                • Feb 2013
                                • 6614
                                need to remove / clean the old solder to see howmany beds.. now they look shorted together
                                • Pipolups
                                  Corsair K70 LUX RGB dying LEDs
                                  by Pipolups
                                  Hi there !
                                  I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                  Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                  10-08-2024, 11:58 AM
                                • max789
                                  Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                  by max789
                                  Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                  I made the following tests:
                                  1. Disconnected the main board from Power Board = backlight works.
                                  2. Connected the main board and disconnected the T-Con = backlights does not work.
                                  So I ordered a main board from Ebay also BN41-02156A but from...
                                  01-18-2024, 06:56 AM
                                • bpcannan
                                  VIZIO M557-G0: Backlights or ???
                                  by bpcannan
                                  'Morning,
                                  I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                                  Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                                  I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                                  I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                                  10-29-2023, 06:36 AM
                                • Misterfixit
                                  Sharp LC-58Q7330U No Backlight
                                  by Misterfixit
                                  This set has the known reputation of failed led backlights. The set does not turn on, but when plugged in, the power led stays lit for about 5 seconds followed by two short blinks and then it repeats itself. While shinning a flashlight on the screen, you can make out the Sharp logo, then it goes out and repeats the cycle. I measured some voltages across the led backlight connector. What has me puzzled is that when I place the negative lead of my vom on the led backlight pin connector (in which the black wire going to the leds was), I measure as high as -228volts, and then it falls to -95 volts...
                                  06-04-2023, 07:39 PM
                                • jesterace
                                  Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
                                  by jesterace
                                  Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
                                  However, I am in a dilemma.
                                  I tested the backlight outputs with the lights disconnected...
                                  10-20-2024, 10:15 AM
