help me mf3010 err 202
  • yacineh
    • Mar 2020
    • 7
    • algeria
    Help with a printer
    Cancel Error 202 for Scanner
    Is there a solution to cancel the copier and make the printer print only and dispense with the scanner?
    Thank you
  • re-atari
    Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
    by re-atari
    Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
    Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
    02-03-2025, 06:49 PM
  • Sam Scarbo
    Brother DCP-L2540DW scanner/printer - only showing blinking screen in LCD.
    by Sam Scarbo
    I got this broken printer from my brother who got it from the street. He asked me to help to fix it.
    I need help on fixing this machine.
    Issues/Observations:
    1) When connected to power, it's not working. Only showing blinking screen on the LCD. See pics 1 and 2. It is blinking every 2 seconds.
    2) I pressed the buttons on the control panel to see if there is any response. The "Options" button can turn off the LCD screen, and then press hold the power button for about 1 second can turn the blinking screen back on again. Other than...
    10-19-2023, 10:32 PM
  • Curious808
    Brother HL-2140 laser printer: printer error (solved)
    by Curious808
    SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
    Windows 10
    Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
    Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...
    06-22-2023, 11:11 PM
  • Artefil
    HP officeJet 8012e ... A printer update will be installed to fix this problem
    by Artefil
    One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
    On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
    The screen displays the following message :
    "a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
    But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
    Have you ever...
    09-28-2023, 05:11 PM
  • waigy
    What are these components that detect paper in a fax scanner
    by waigy
    PROBLEM SOLVED
    I DIDN'T REALISE MY SMALLEST SOLDERING TIP COULD JUST FIT BETWEEN THESE COMPONENTS.
    I MANAGED TO REMOVE THEM WITH NO DAMAGE TO THE BOARD AND I HAVE MY INTENDED END RESULT.
    On a Possio PM70 portable fax machine which has a scanner that detects when you push a piece of paper into the scanner slot.
    It is these two small (3mm long) components that detect the paper and start the scanner feed motor which pulls the paper into the scanner.
    (These are on the circuit board for the keypad and not the main board)
    I want to disable these as...
    05-21-2023, 12:50 AM
