HP Inkjet printer main board bulging cap failure
  • howardc64
    • Jun 2017
    • 525
    Fixed a 10yo HP inkjet with a bulging cap on the digital computer power rails (1 to 5V). Unstable voltages causing these inkjets to not boot properly or crash quickly. Seems like more and more of these are showing up nearing the 10 year mark. Board design seem to look similar for many of these printers.
    https://h30434.www3.hp.com/t5/Printi...t/true#M997922
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
  • smile
    Brother MFC Inkjet Printer prints Unidirectional mode only?
    by smile
    My friend brought his MFC-5895 for repair. Same problem "No ink in the ink tubes". Quick FIX when you have 3D printed parts.
    But his printer has this problem of only printing in Unidirectional mode, else the text is blurry.
    All service manual adjustment done and make no difference.
    timing strip is OK
    See nozzle check is also out of alignment.​
    12-27-2024, 05:34 AM
  • cmlewis89
    LG 47LB5DF blown power supply board
    by cmlewis89
    Hi folks,
    I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
    09-03-2024, 07:50 PM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • Curious808
    Brother HL-2140 laser printer: printer error (solved)
    by Curious808
    SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
    Windows 10
    Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
    Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...
    06-22-2023, 11:11 PM
