Is that true that u can lift up the write data pin to prevent printer from writing absorber count to the chip. Which pin to lift up?
Epson Absorber counter
by shamsudeenEpson M3170 Monochrome inkjet printer adjustment program tool.
Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
anyone having it, please share
Thank you -
by re-atariHello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he... -
by valente222hello everyone.
I need binary for Epson L3150, this printer is something special today. It happens that when you connect USB to the PC, it does not recognize drivers nor does the software even find it to load the emergency firmware again. The device only turns on and the power button LED remains constantly on. The head normally comes to its ready position but does not react to buttons or scan. I point out that I have also tried installing a new head, scanner or new button panel... but it is still in a vegetative state. Has this ever happened to anyone?... -
by Curious808SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
Brother HL-2140 laser printer
Windows 10
Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...06-22-2023, 11:11 PM -
by ArtefilHi,
One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
The screen displays the following message :
"a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
Have you ever...09-28-2023, 05:11 PM - Loading...
