Lexmark T522 - 954 NVRAM Failure
  • Agent24
    I see dead caps
    • Oct 2007
    • 4950
    • New Zealand
    No idea if anyone here knows much about printers, but thought I've give it a shot.
    I've got a Lexmark T522 which gives this error "954 NVRAM Failure" at every startup. However, turning it off and on again after a few seconds makes it work normally.
    The service manual says "Indicates the NVRAM experienced a CRC failure.
    Replace the engine board." - engine board = $260+
    My first guess would be that the EEPROM is failing, and it might be wise to try dumping the contents and then replacing it, but I know that of course it could just as easily be something else.
    Anyone here got experience with this kind of thing?
    -David VanHorn
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Lexmark T522 - 954 NVRAM Failure
    Have you tried an NVRAM reset?
    http://www.lpt.com.au/support/954StdNetworkError.html
    Maybe there's a small rechargeable battery that keeps the NVRAM contents alive and it's dying? I looked at the service manual and it seems there's not that many parts on there... have you checked for bad caps?
    Otherwise posting several large, focused pictures of the board in question (just like with LCD troubleshooting) can help us identify components if you need help with that.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4950
      • New Zealand
      No, didn't try a reset. Might give that a go first then.
      I didn't see any battery from the manual photos but there could be one there.
      I'll try to drag it out of its corner when I have time and have a look inside, get some good photos perhaps. Would be interesting to see what capacitors they use in the PSU at any rate.
      -David VanHorn
      • Agent24
        I see dead caps
        • Oct 2007
        • 4950
        • New Zealand
        I ended up having a quick look the other day - when I had to uh... 'clean' the fuser out after running a sheet of plastic I thought was a laser-transparency but actually wasn't.
        Capacitors in the PSU all looked like UCC or such, and seemed just fine. Now that I know how to get the thing apart I'll probably take a better look soon. Most parts just snap into place - very few screws actually, which is nice!
        -David VanHorn
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          Replaced emmc.
          Terminal log
          UART
          AC_ON
          E-B
          FDE enabled
          06-01-2025, 02:11 AM
        • ctroxtell
          Carrier HK50AA063 display controller common failure help
          by ctroxtell
          I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
          02-05-2025, 05:31 PM
        • howardc64
          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
          by howardc64
          Problem
          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
          Model & Board Pics
          Conflicting Spec
          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
          https://www.shopjimmy.com/vizio-gj-2k1...
          10-10-2024, 01:16 PM
          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
          I was working on this CNC machine today found no keyboard functioning no control relay powering on
          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
          Found shorted diodes on main controller relays there are 3 of them that...
          01-07-2023, 05:43 PM
        • freakaftr8
          Asus a15 FA507RE-A15.R73050T failure
          by freakaftr8
          So this laptop seems to have some kind of failure. I bought it second hand and originally the previous owner said that they went to turn it on and it was presented with a quick flash of the power light the keyboard lit up and then the keyboard shut off and the power light went off as well but the battery indicator was white and after about 5 to 7 Seconds flashes orange really quick then shuts off and goes back to White. If the power button is pressed again the keyboard lights up really quick and then repeats. When I got it I could press the power button multiple times the keyboard light would...
          03-28-2024, 10:58 PM
