Hello, I have a pantum Printer Model: P2500 FW version: 3.2.2.8 I want to run it without chips, but I can't do it from nochip.ru, I wonder where else to do it?
Pantum P2500 NoChip Reset
for all printer and firmware modification experts
I've been working on the above named printer toner chip trying to read with ch341a and other devices but seemingly the chip burns after a while and needs to be replaced and printer doesnot get ready
anyone can help about this printer chip or firmware modification ways
08-16-2022, 09:07 AM -
by re-atariHello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he... -
by Curious808SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
Brother HL-2140 laser printer
Windows 10
Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...06-22-2023, 11:11 PM -
by ArtefilHi,
One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
The screen displays the following message :
"a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
Have you ever...09-28-2023, 05:11 PM -
Hey there people
While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
This is what I tried, but not in any order.
Google
YouTube
BIOS
Command Prompt (administrator privileges)
On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...-
10-25-2025, 02:22 AM -
- Loading...
