Navitel R1000 GPS camera bricked while updating, dump needed.
  • thesame
    • Mar 2018
    • 141
    • Romania
    This camera was flashed by the owner and after update it starts displaying NAVITEL and that is all.
    I have contacted Navitel help , they sent me one file called SdFwCode.bin and the firmware SD_CarDV.bin which i have uploaded here in a zip file together with a backup of the actual dump thats on the camera.
    These two bin files they say that i have to copy into an microsd card formated fat32 not bigger then 32Gb and to install the card into the camera.
    So first i had to press the M button on the camera , while keep pressing it i have to plug power cable into camera then press power button while keep holding the M button and the camera was suposed to update the firmware but it my case it does nothing. I have tryed with several micro sd cards, i have also programmed the flash memory with my programmer using the SD_CarDV.bin which is the update file from their website but i get no image on the display.
    If someone can help me compare the bin that i made a backup of with the one from their website and maybe we can make one good bin from the two files.
    • 31260
    Re: Navitel R1000 GPS camera bricked while updating, dump needed.
    check the M button actually works
    • petrservis
      • Aug 2023
      • 3
      • CESKA REPUBLIKA
      Hi Thesame.
      Your files are fine, the SD_CarDV.bin file is the same as the 20230823_105532_SVOD3.bin file
      METHOD:
      01. FAT32 card format in PC
      02. upload files SD_CarDV.bin + SdFwCode.bin
      03. insert the SD card into the switched off camera
      04. hold the M button
      05. connect the power cable directly to the camera
      06. STILL hold the M button + hold the ON button until the RECOVERY message appears on the camera display.
      07. release the buttons and wait until the Navitel logo appears on the display and the camera turns off.
      08. turn on the camera with the ON button and make new settings - everything is in factory settings.
      Good luck.
      Peter
      PS: I'm using an automatic translator, so I apologize for any mistakes.
      • thesame
        • Mar 2018
        • 141
        • Romania
        I have tryed it several times, i have to check the M button to see if it actually works like STJ replyed, it does nothing when trying the recovery procedure, display is black, i was holding both M and Power with the power connected for 30 seconds and the display does not turn on, only when releasing M and pressing power button it does start displaying the logo.
        Then if the both files are the same why when i flash SD_CarDV.bin with the programmer i get no image?
          • 31260
          how did you format the card?
          a lot of people have problems with games consoles because windows does not format stuff properly
          • petrservis
            • Aug 2023
            • 3
            • CESKA REPUBLIKA
            Hello.
            When possible, send me the full serial number of your Navitel camera - it is written on the camera near the buttons.
            Petr
            • petrservis
              • Aug 2023
              • 3
              • CESKA REPUBLIKA
              Hello.
              It is possible to install newer firmware from serial number R1000201710xxxxx.
              Unfortunately, lower production numbers do not have this option.
              Peter
              • thesame
                • Mar 2018
                • 141
                • Romania
                Originally posted by petrservis
                Hello.
                Petr
                This is the serial : R100020190501095
                • thesame
                  • Mar 2018
                  • 141
                  • Romania
                  Formated in windows from right click menu format selected file system FAT 32 and default alocation unit size, tryed with quick format and also low level format with two different micro sd cards.
                    • 31260
                    https://www.majorgeeks.com/files/det...t32format.html
                    try this
                    • thesame
                      • Mar 2018
                      • 141
                      • Romania
                      I have formated the microsd with the tool copyed files but with the same problem, i think the microsd are ok , the problem is in the camera itself.
                      • Pankos
                        • Mar 2024
                        • 3
                        • Эстония
                        Originally posted by thesame
                        SdFwCode.bin
                        Bricked my device the same way and found this thread. Can't seems to find zip file anywhere here. Would you be so kind to share it once again.
                        • thesame
                          • Mar 2018
                          • 141
                          • Romania
                          Of course , i have uploaded an archive for you , the backup file made from the bricked one its with the name 20230823_105532_SVOD3.bin and the rest are the update files that you need to update with micro sd. Follow the instructions.
                          • Pankos
                            • Mar 2024
                            • 3
                            • Эстония
                            Thanks a lot! Coincidentally today I also got a response from Navitels support and they provided me with instructions. According to instructions, I have to use micro sd card of 32 Gb or less capacity. Although original Sd card shipped with device was 64 Gb and I asked them If I actually could use my original Sd card. They said: NO. I wonder If this was the cause of the failed update in the first place. Now I need to get a new micro SD card somewhere just to recover a device. Hopefully it will work.
                            • ed hunter
                              • Jun 2024
                              • Poland
                              Can I use the same SdFwCode.bin file for serial number: R105020191003808 ? If no - could you please provide it? I wrote to Navitel but no response...
                              I already have the latest SD_CarDV.bin​ file from theirs website. Thanks for answer in advance!
                              • Pankos
                                • Mar 2024
                                • 3
                                • Эстония
                                I already have the latest SD_CarDV.bin file from theirs website. Thanks for answer in advance!
                                Recovery file is for R1000 model:
                                https://navitel.com/en/devices/dvr/navitel-r1000
                                My device's S/N: R100020190501930
                                You could use it at your own risk.
                                • domdom777
                                  • Feb 2025
                                  • Polska
                                  Hello
                                  Do you have recovery R1050.
                                  Thank you
                                  • Joones
                                    • Jun 2025
                                    • Cabara
                                    Has anyone any experience with the R600 dvr? same symptoms, when turned on or connected to charger it makes welcome sound and keeps displaying Navitel logo.
