IBM Aptiva 2144 Power Supply Repair Magnetek
  • mitchw
    • Dec 2016
    • 152
    • Slovenia
    I just got an old IBM Aptiva 2144 model that worked for a minute and shut off.
    The culprit was the Magnetek PSU that failed. Acutally the reason it failed was a bunch of leaky capacitors that were slowly destroying the PCB.
    In the past, I had problems with Magnetek, as they used something like a Daewoo capacitors that a lot of them read completely open, but with no leakage. This time, the caps leaked. Only 2 or 3 of all caps were still okay.
    So, after a drilling out the rivets, disassembling the PSU and recapping it, it works.
    The leaky caps were:
    Nippon Chemi-Con LXF
    Samwha RG
    Nichicon PF
  • mitchw
    • Dec 2016
    • 152
    • Slovenia
    Re: IBM Aptiva 2144 Power Supply Repair Magnetek
    Found more problems, the soldering also isn't very good on this power supply.
    All working 100%
    See the attached photos of a badly cracked joints
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      Hey, nice job.
      "Made in Italy," it's a keeper!
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • mitchw
        • Dec 2016
        • 152
        • Slovenia
        Thank you. "Made in Italy" is usually good to see on food, but not on electronics
        Magnetek branded PSUs were also used on first PowerBook Duo Docks and those also all need recapping. Also they are riveted together, which means you need to drill out the rivets, etc. Major PITA. This IBM one was also riveted, I guess all of Magnetek PSUs were.
        Also traces are thin as paper and lift really easily, even with care. But still, when working, they work fine.
          • 31304
          the good thing about rivets is when you see them you know you didnt re-cap it yet!
          • PeteS in CA
            • Aug 2005
            • 3586
            • USA, Unsure of Planet
            I think I saw a "9527" date code on an IC, and the LXF series is quite old. Also, it looks like the output connector is pre-ATX.. Lasting 20 or 25 or 27 years is rather respectable. I'd suggest replacing the LXF caps with a very mature Nichicon or Chemicon low impedance series.
            PeteS in CA
              by sam_sam_sam
              03-31-2024, 02:12 PM
              by sam_sam_sam
              07-01-2024, 06:34 AM
            • shamsudeen
              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
              by shamsudeen
              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
              i know that in linear power supply the noise will be very low comparing to SMPS supply....
              07-19-2025, 07:14 AM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
