Delta DPS-150GB PSU failure
  • powermax
    • May 2017
    • 49
    Hello crews,
    I got a faulty Delta DPS-150GB PSU from a Power Macintosh G3 Beige.
    The computer has suddenly stopped working.
    I checked the PSU and found out that there is no voltage on the trickle rail. That explains why the Mac doesn't power on.
    An initial visual inspection has revealed neither blown components nor bulging/leaking caps. The main fuse is good, too.
    Judging by the markings on the PCB, the PSU was built in April 1998.
    I therefore assume that replacing all caps except the big ones won't do any harm.
    Nevertheless, I would like to ask the experienced users here for what can cause the trickle power to suddenly disappear. Is there any component I can check for failure?
    Thank you in advance!
    P.S.: I had to desolder C901 in order to determine its capacity because the marking was hidden by a huge blob of glue...
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Delta DPS-150GB PSU failure
    Replacing all small electrolytic capacitors is certainly a good idea when the unit is 25 years old, it might just fix it.
    One way to perhaps confirm that is to heat the unit up to ca 50°C or so, if it then starts you can be pretty sure it is the small caps.
    But this does not always work if they are too far gone / completely dried out...
    • powermax
      • May 2017
      • 49
      I have a device for measuring various components. It shows the following for the desoldered 100 uF cap (C901):
      112,5 uF
      ESR = .41 Ohm
      Voss = 1,5 %
      (see the attached picture)
      I could measure all caps after desoldering. Would that be meaningful?
      I have no possibility to heat up the PSU to 50° without risk of damaging the unit...
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Yes remove all small caps and test them but just a note: let them cool down to room temperature before measuring otherwise the data will be better than in reality (exactly like in the proposed heat test)
        • powermax
          • May 2017
          • 49
          For 1 uF and 2,2 uF caps, my testing device measured the ERS > 2 Ohm.
          The ERS of the other caps lays below 1 Ohm.
            • Jul 2011
            • 6070
            Can you please post the exact value of the 1uf and the 2.2uf thanks
            Because if the value is over 1.5 ESR I question how good this capacitor is and the closer it gets 2 and over compared to a new one led me to change them anyway just for good measure but that just me personally
            I also do a test with them @100*F then let them cool down to room temperature and to the temperature of your air conditioning vent which would be around 50*F or so if you get a result of more than 10% between these two results I would highly recommend that you replace them
            • powermax
              • May 2017
              • 49
              Markings: 1uF 50V
              Measures: 948,1 nF, ESR = 2,4 Ohm, VLoss = 0,4 %
              Markings: 1uF 50V
              Measures: 938,2 nF, ESR = 2,2 Ohm, VLoss = 0,4 %
              Markings: 2,2 uF 50V
              Measures: 2180 nF, ESR = 2,1 Ohm, VLoss = 0,9 %
              • powermax
                • May 2017
                • 49
                I'm looking for replacement caps. I have a couple of Chemicon KY ones and wanted to order more of the same kind but they seems to be discontinued by the manufacturer.
                These look like a good replacement to me:
                https://www.mouser.de/ProductDetail/...WCriJgLQ%3D%3D
                https://www.mouser.de/ProductDetail/...S0Pc4Y1g%3D%3D
                The difference is in the ESR. The former is rated at 900 mOhms while the latter is 400 mOhms.
                Which one fits better?
                  • Jul 2011
                  • 6070
                  I would go with 50 volt ones not 25 volt ones
                  KY or KZE would be just fine I use them all the time if they are available
                  • powermax
                    • May 2017
                    • 49
                    Well, the unit originally had three 25V and one 50V Rubycon caps.
                    Chemicon KY isn't available anymore. KYA 50V is a bit thicker - I need to check first if they fit into the available space.
                    KZE caps have a rated endurance of either 2000 or 10000 hours.
                    Rubycon offers 5000 hours as well...
                      • Jul 2011
                      • 6070
                      You could go with LXZ which both values are available in 25 volts ( and also available in 50 volt as well ) they automotive type capacitors I uses these quite often as well also LXY but not always available in all UF values
                      I have use both of them in switching power supply with no issues
                      I have to wonder if KY and KZE are being phased out for some reason because they are not very many UF values available anymore because I still have 1, 2.2 , 22 and other values as well still my in capacitor bin but getting low on some of them but they were bought ( a few years ago to more than several years ago )
                      because when I buy these low value capacitor I buy them 100 at a time that is why I still have so many still available in capacitor bin
                      • PeteS in CA
                        • Aug 2005
                        • 3583
                        • USA, Unsure of Planet
                        I doubt that the caps used in that P/S were as low impedance as KY or KZE. LXV, PS (= PR), LXZ, or PW would probably do well for both output caps and smaller value decoupling and start-up caps.
                        That P/S predates 1A-3A 5VSB designs. You may have to draw your own schematic, possibly working your way back from the "Trickle" output wire (violet?). The IC mounted on HS1 may be part of that circuit.
                        PeteS in CA
                        • powermax
                          • May 2017
                          • 49
                          Is the schematic for a 1A-3A available somewhere?
                          • powermax
                            • May 2017
                            • 49
                            It looks like the only series that offer 1 uF and 2,2 uF @ 50V caps is SMG (SMQ-E).
                            Okay to go with them?
                            • powermax
                              • May 2017
                              • 49
                              I replaced 10 small electrolytic caps as suggested above. Then I plugged the power supply into the wall socket and checked the trickle pin with the meter. It showed 4.95V power.
                              I wanted to test the PSU without connecting it the motherboard. I found a post in the macrumors forum that describes how to turn this PSU on: one needs to wire the TRKL and the PowerON pins together.
                              The corresponding thread is here.
                              I connected the pins as described above but the PSU didn't start. The fan didn't spin on but the trickle power has disappeared.
                              It looks like the PSU is completely dead. The current situation is the same as earlier: nothing is visibly blown, the main fuse is still conducting power.
                              Is there anything I could do before throwing it away?
                              • JohnnyPhantom
                                • Apr 2013
                                Was the power supply ever fixed? or just tossed out? I have the same model and same issues myself. Hate to toss the machine out, hoping to fix.
                                Thanks!
                                ~John
                                  MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                                  This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-07-2024, 03:40 AM
                                • npielawski
                                  MacBook Pro late 2016 (820-00239) with multiple failure modes.
                                  by npielawski
                                  I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                                  I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                                  10-15-2025, 01:53 AM
                                • Junkrepair
                                  Calculating ESR from tan delta -- tan delta's dependence on capacitance
                                  by Junkrepair
                                  I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                                  I found this nice little description of the conversion:
                                  Calculating capacitor ESR from Tan(delta)
                                  https://forum.digikey.com/t/calculat...-from-tan/2633
                                  It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                                  06-12-2023, 02:45 PM
                                  MSI Delta 15 A5EFK-081AU Notebook 15 Specification for Upgrade or Repair
                                  This specification for the MSI Delta 15 A5EFK-081AU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-081AU boardview and 15 A5EFK-081AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-07-2024, 06:11 AM
                                  MSI Delta 15 A5EFK-046UK Notebook 15 Specification for Upgrade or Repair
                                  This specification for the MSI Delta 15 A5EFK-046UK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-046UK boardview and 15 A5EFK-046UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-07-2024, 05:50 AM
