hello, i recycled a torroidal transformer from a speaker, i want to know how much amps of this transformer, olease help me identify, i will be using this to build my bench psu
identify torroidal transformer amperage
Re: identify torroidal transformer amperage
That is interesting using weight and cross-section of windings. Most likely you would not need the dimensions as you have the voltage rating of the primary and secondary. I would image only a certain cross-section of a primary and secondary can weigh that much and deliver that voltage?Comment
Do you still have the device that this came out of it should have data plate on it so you can get a rough estimate of it amperage
One note I would first start by putting a rectifier diode assembly with no load on it for an hour so you have a reference point and go from there
Then I would just estimate it current by putting one amp load let it run for an hour and take it temperature and if not that warm then go to 2 amp load and keep going up as long as your transformer does not get so hot that you can not keep your hands on it
I did a quick search for audio toroidal transformer and most of them that I saw were in a amperage range of 1 to 3 ampsLast edited by sam_sam_sam; 05-14-2022, 02:40 AM.Comment
hi sam, i only have the transformer now, yeah i connected a bridge rectifier without caps and load, i run it like that for almost an hoir, the temps of the transformer felt like normal, not hot , jus normal temp i have no thermal scanner to exactly do temp meas, one thing i did not do is to put a load on it, anyway can you guess the amps based on its marking? BX1201Comment
Here is a link for you.hi sam, i only have the transformer now, yeah i connected a bridge rectifier without caps and load, i run it like that for almost an hoir, the temps of the transformer felt like normal, not hot , jus normal temp i have no thermal scanner to exactly do temp meas, one thing i did not do is to put a load on it, anyway can you guess the amps based on its marking? BX1201
https://www.electricaltechnology.org...nsformers.htmlComment
As I remember if one has say 200 volts on the primary winding at 1.5A and you drop down to say12 volts on the secondary your current will be inversely proportional to the primary. You would set up a proportion like 200/12=X/1.5 Solve for x to get current in secondary.Last edited by keeney123; 05-16-2022, 04:36 PM.Comment
Is the 28V-0-28V one winding with +28 volts, center tap 0V, and -28Volts? if it is one winding than the voltage difference is 56 volts. You would then be going from 230V to 56V. If they are separate winding then you would figure them individually. Also, remember that the fuse rating is 1.5 A so the actual current will be less. Usually a engineer will make a safety factor of 40%. The actual current could be 1.5x.6= 0.9A I believe a 1A 230 primary is a realistic supply.Last edited by keeney123; 05-17-2022, 11:44 PM.Comment
110VA
based on weight and outputs
using these as reference:
https://uk.rs-online.com/web/p/toroi...ormers/2238049
https://uk.rs-online.com/web/p/toroi...ormers/7581042Comment
What I have read is that normally with a transformer when figuring out VA they use a power factor of 0.8 but, these types of transformers are more efficient for the power factor. It becomes 0.9 This can be looked upped online on how to figure it out. Basic understanding is that the primary has just so much power figuring on current and voltage. That power will be transmitted through to the secondary at a loss. Although the magnetic transference is 99% efficient i guess the power takes a hit by 10% in this case.Comment
by robybi managed to break off a transformer from my Imac a1418 logic board when i was mounting it back.
it's this one and i cannot identify it so i can order a new one.
Also it would help if someone can tell me if it could be the reason why my Imac will not start.
The green led is "on " on the motherboard , but when i hit " power on" nothing happens.
i will attach the schematics here.
...11-16-2022, 04:17 AM -
by ohrenHello!
I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
Measured voltages with no load:
After rectifier diodes
12V: 6.17 V
5V: 5.67 V
Secondary transformer pins AC measurement (really don't know if this says anything)
12V: 2-2.5 V
5V: 1.04 V
I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,... -
by dennis_elx33Hello All,
i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
Problem statement: Power tripped Off
Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
Action Done:
1) Replaced the faulty parts with good spare.
2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will... -
This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 04:40 PM
This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 12:00 PM
- Loading...
