MP-3314 multi-voltage plugpack - fails under load
  • dkneyle
    • Dec 2013
    • 441
    I know these things are only worth a few dollars, so this is perhaps more an intellectual exercise in understanding what is (not) going on here.
    The model is marked as MP-3314, sold in our consumer electronics stores, and is variable between 3V and 12V at 1.5A.
    Under no load it shows as the appropriate voltage - set currently at 9V. But under load it fails, the LED flashes/blinks as it tries to restart. Meter shows volts come up but fall back with a fraction of a second, repeated continuously.
    What would be a typical component that would fail, producing this effect?
    Images attached of both sides of board.
    By the way, have confirmed the device it is driving is OK. I have wired in my bench variable supply and all works 100%
    • 31262
    Re: MP-3314 multi-voltage plugpack - fails under load
    3v @ 1.5A
    probably means 6v @ 750mA and 12v @ 375mA
    whats your load and where is the primary's heatsink?
    • R_J
      • 9610
      There is a small value electrolytic in the primary I would replace first, In your picture it is the one located next to the transformer below the mosfet.
      • petehall347
        • Jan 2015
        • 4447
        • United Kingdom
        clean the solder side of the board and resolder the bad joints
        • dkneyle
          • Dec 2013
          • 441
          Originally posted by stj
          3v @ 1.5A
          It's driving one of these cheap and nasty Chinese all-in-one Hi-Fi (actually Lo-Fi) units with a turntable, CD player, radio. The specs on the unit say 9V @1500mA.
          And what you see in the images is what you get. No heatsink to speak of.
          I think you are probably correct. Simply can't supply the required load.
          I found a 12V 2A plugpack in my junkbox and gave that a go. It powers up and runs. But there is a oscillation tone coming from the speakers that is reasonably prominent. Hard to image that 3 volts would make much difference? But I certainly didn't hear any of that when I was running it off 9V from my bench supply. Just cheap and nasty electronics all around I suspect.
          • yaya3gmax
            Laptop Power Issue – Works on Battery, Fails on Adapter Load
            by yaya3gmax
            Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
            Symptoms:
            • Laptop works normally on a pre-charged battery.
            • Battery does not charge when adapter is connected.
            • Without battery:
              • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
              • Speakers “pop” when power cut occurs indicating harsh sutdown.
              • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
            08-21-2025, 07:16 AM
          • AJ847.63e
            Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
            by AJ847.63e
            Hi Folks,
            Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
            I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
            The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
            05-06-2025, 10:37 PM
            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-12-2024, 02:20 PM
            HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
            This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
            09-06-2024, 10:56 AM
            HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
            This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
