Need help identifying a 14 legged chip with no marking
    • Jul 2011
    • 6070
    Re: Need help identifying a 14 legged chip with no marking
    That great that you did get it working correctly again
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • DynaxSC
      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
      by DynaxSC
      Hi
      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
      08-04-2025, 12:20 PM
    • skdsp
      Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
      by skdsp
      I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
      Attached is the photo.
      Thank you!
      09-27-2025, 09:05 PM
      Common SPI bios chip programming Questions and Answers
      by SMDFlea
      Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
      A: If you can`t read from it how do you expect to write to it ?.
      Q: Why is my bios chip unreadable ?.
      A: The programmer is faulty or has a worn or broken zif socket.
      The USB cable is frayed,connector pins worn or some other physical damage.
      Not enough amperage or voltage to power the programmer properly.
      Bad...
      09-02-2021, 04:40 PM
    • trepachka
      Help identifying this chip for Yoga 7 16IRL8
      by trepachka
      This chip is shorted thru. Based on what I see, it's either a 3.3V or 5V buck converter, just my guess. The markings on the chip state "S2=AB".
      A photo of the chip is attached.
      Thank you....
      06-22-2025, 11:13 PM
