ATX PSU Tester Analyzer modification / upgrade
    • 31289
    Re: ATX PSU Tester Analyzer modification / upgrade
    so before it gets out of hand,
    lets decide how bad the 5v can be.
    personally i think it should be checked seperatly first.
    ripple will be an issue - it will mess with voltage regulators - BUT if you smooth it then your effecting the reading the meter will give you.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8711
      That can be mitigated, definitely need diode isolation.
        master hoarder
        • May 2008
        • 12175
        Cool mod, Rich. I probably wouldn't have the nerves to spend as much time modding such a tester, as I find these are pretty useless for testing PSUs. Probably the only useful thing they measure is the PG delay.
        Now, if combining one of these testers with a resistive load tester for the PSU's output rails, that might actually be useful to see how the voltages from the PSU behave. Add an o-scope on the output of the PSU, and you have an inexpensive and more or less proper PSU tester.
        Originally posted by eccerr0r
        I really don't know why they used 12V to power initially, seems that you should be able to use 5VSB for nearly no additional cost, granted it will require it to be at least 3 or 4 volts for it to power whatever chips the tester uses. As said multiple times, ATX PSUs that don't have 5VSB working cannot turn on because that's what powers the !PSON - for both isolation and for keeping voltages within reasonable limits. Note that in the normal case, motherboards need 5VSB to power their switching circuitry, can't assert !PSON without any power.
        +1
        Can't think of any reason not to power off of 5VSB other than if your meter draws more than 100mA - because ATX1.0 did not specify much current for 5VSB.
        Agreed... though I think even most old ATX PSU's could do at least 500 mA to 1 Amp, so I don't think that should be an issue here.
        Hopefully bad cap ripple on 5VSB doesn't blow the tester...
        Yes, that, or over-voltage like might happen with PSU's with 5VSB circuits similar to the suicidal Bestec ATX-250-12E. But even then, that should be pretty easy to take care of with a regulator of some sort inside the tester. I imagine even something simple like a series resistor and cap should work just fine to mitigate any ripple, and then perhaps a 5.8V Zener diode (5.1 Zener + regular diode in forward mode in series) to shunt anything over 5.8V to ground, in case the 5VSB does decide to go crazy.
        Originally posted by stj
        not that brand though - no DuraLeak.
        +1
        Avoid Duraleaks and Durabulges.
        IME, at least, their 9V batteries don't leak (too much), but frequently bulge to the point where I have to pry them out with a big fat screw driver, because they got stuck.
        The AA and AAA's are absolutely terrible leakers, though - rarely they last more than 6 months on the shelf. The last AAA's my mom bought for her MP3 player that she takes sometimes when walking around, started leaking just within 3 months of purchase.
        But anyways, that's besides the topic discussed here.
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          Errmm, I believe the use of the boost converter also mitigates against this sort of problem as the 'delicate' electronics are hidden behind both the boost converter and the original LDO
          Follow me on YouTube
          Learn Electronics Repair
            master hoarder
            • May 2008
            • 12175
            True.
            I just tend to favor solutions with less/minimum parts, and highly preferably stuff I already have in my scrap bin so I can recycle components. Of course, I do like those tiny little boards from Ebay a lot (be it boost, buck, LDO, or any other type of converters and whatnot) as they tend to do a really good job for what they are made for. I feel like I cheated a little every time I use one, though. That's probably just me being weird, though. Hence my suggestion for the RC low-pass circuit and Zener reg/protection.
            I suppose as the saying goes, there's more than one way to skin a cat.
              Modification done to a EBC-A40L 5volts Battery Capacity Tester 40A for less noise when charging / discharging cycles
              When I first turned this battery testing machine the fan for the switching power supply was a little bit noisy but once I recapped the switching power supply board it quiet down considerably then I put a temperature controlled fan that does the mosfets control board was really noisy but now that it is cooled with temperature controlled fan that sensor was moved from the fan to the heat sink so now that the fan is controlled this way the fan runs according to the temperature of the heat sink
              This switching power supply was really fun to recap the quality of the board was very good...
              02-25-2024, 08:55 PM
            • Petr0x
              Bosch 12V and 18V chargers modification
              by Petr0x
              Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
              You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
              Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
              05-24-2024, 01:00 PM
            • Teban1306
              [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
              by Teban1306
              Hello everyone!
              I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
              System Information:
              • Model: Lenovo ThinkPad T14 Gen 1
              • Machine Type: 20S1S4E600 (Intel i7 variant)
              • Current BIOS: N2XET42W (1.33) - Latest version
              • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
              What I'm trying to achieve:
              Replace the default "LENOVO" boot logo with a custom image during POST.
              🔧 What I've tried:
              09-14-2025, 11:49 AM
            • howardc64
              Don't probe Samsung LED conector with LED tester, connect may not make contact afterwards
              by howardc64
              Samsung have been using this style LED connector for few years now
              Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
              The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open...
              10-12-2025, 08:13 PM
            • Lifeisfun
              Trying to troubleshoot DDR4 SODIMM slot with slot tester
              by Lifeisfun
              Hi folks!
              I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
              Eventually I discovered that it was related to moving the laptop.
              Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
              If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
              I removed the board got one of those memory slot testers...
              06-04-2025, 02:26 PM
