Oh, Deer!!
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Oh, Deer!!
    I have a Deer 250W ATX power supply! It's from my first PC, which was a K6-2 450 mhz processor and Soyo SY-5EMA+ motherboard (built in December, 2000), then was still used with my Athlon T-bird 900 mhz and Soyo SY-K7VTA-B motherboard (purchased in June, 2001). It was actually stabler, then my first setup, once I solved a BIOS problem. Even with that power supply, it was stable when it wasn't OC'ed.
    It in fact was in repeated use until July 5, 2002. I couldn't recall it being hot either!
    All of the caps appear to be fine.
    The caps:
    2
    Viva (LOL!)
    470uF
    200V (the 2 monster caps) --Clean as a whistle!
    Rulycon (sorry, not Rubycon!!)
    2200uF 10V--Clean as a whistle. They appear to be fine.
    Rulycon
    2200uF 16V--Clean as a whistle. They appear to be fine.
    Jun Fu (only 1)
    100uF 25V--Clean as a whistle. This one appears to be fine.
    Capxon
    2.2uF 50V--Clean as a whistle. They appear to be fine, too!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Oh, Deer!!
    But, what the bleep? Part of the PCB is darker!!
    There appears to be a problem with at least 4 of the resistors overheating!!
    Arc A770 16 GB
    • Rainbow
      • Aug 2005
      • 1375
      Re: Oh, Deer!!
      I think that these PSUs might have the same problem as EuroCase - https://www.badcaps.net/forum/showthread.php?t=831
      The voltage from the aux power supply might be too high.
      • Chris1992
        • Apr 2005
        • 561
        Re: Oh, Deer!!
        Hey, RJ, what camera are you using to take those pics? They are blurry as hell. And you are VERY lucky to have that Deer PSU without visibly failed caps.
        The great capacitor showdown!
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Re: Oh, Deer!!
          Creative PC Cam 300.
          Arc A770 16 GB
          • Chris1992
            • Apr 2005
            • 561
            Re: Oh, Deer!!
            webcam-type (: Ask Rainbow for tips on webcam pix cos he (?) takes pics with an ancient webcam and they are decent.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              Re: Oh, Deer!!
              Would those be the resistors that appeared to be cooking or transistors?
              Does someone have a schematic drawing for Deer PSUs?
              Arc A770 16 GB
              • Rainbow
                • Aug 2005
                • 1375
                Re: Oh, Deer!!
                Resistors near the TL494 (or DBL494 or KA7500B or some other equivalent) chip burn when voltage from the aux supply is too high. The chip is usually damaged too, sometimes also one of the main switching transistors and/or the small transistors that drive them.
                Sometimes a small cap blows (the cover pops off and the guts unroll), often together with the 7805 regulator (that provides +5VSB to the board), causing damage to the board. When I see blown cap and resistors burnt beyond recognition, I don't repair it - it's good source of parts :-)
                The aux power supply is different between different PSUs but the main supply is often very similar.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Re: Oh, Deer!!
                  Edit: the PSU actually has 2 Jun Fu caps.
                  Arc A770 16 GB
                  • mecha1166
                    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                    by mecha1166
                    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                    11-25-2024, 05:22 PM
                  • CapLeaker
                    Dell ATX PSU won’t start, but forcing it works fine?
                    by CapLeaker
                    Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                    Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                    10-28-2024, 06:59 PM
                  • emil_t
                    RTX3090 working fine but fans not spinning
                    by emil_t
                    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                    04-12-2024, 06:54 AM
                  • kotel studios
                    DEER B350ATX PSU - tips on making it safer and "better"
                    by kotel studios
                    Since it looks like my excellent power PSU chances at living are now close to zero, I decided to give a shot at upgrading this DEER B350ATX PSU.
                    At first glance it looks like, well.... a shitty cheaped out DEER garbage (cause it is). Although it does have an LF 1250CD00 filter transformer (at least I think that's what it is) 😆
                    Tiny heatsinks, small transformators, single-pole ON/OFF switch. You name it.
                    Now since this one works, I'd like to know how can I make it safer and better (besides burning it with napal 😃). My plan is to make the switch double-pole...
                    03-04-2025, 12:09 PM
                  • edugimeno
                    TD Systems K50DLP8F works fine on 1 HDMI, bad on others
                    by edugimeno
                    I have this TV set that I spent a long time fixing it.
                    I finally found a shorted SMD capacitor near the plug from the PS at the main board. It was shorting one of the main voltages (can't remember which one)
                    I removed that capacitor, and as it has another one in parallel, I left it with only one, checked it and it seemed to work fine. The solder near that capacitor was really delicate as I pulled apart one trace so I prefered to not mess much with it after I had to air solder one small thread of copper
                    I didn't use that TV much at that time. Now that I'm using it,...
                    10-06-2023, 03:00 PM
