Antec True330 P/S
  • Mustang
    • Dec 2003
    • 203
    Antec True330 P/S
    Greetings! Another Antec bites the dust. PC started freezing up about a week ago and then finally a "pop" when plugging it in. I can see 2 fuhjyyu 1650uF 16V caps with bulged tops. Also 2 other caps have what looks like rust stains on their tops (A capxon 3300 uF and a [M] 680 uF). Is this P/S worth the expense to have it repaired? Other than the bad cap issue, this P/S looks to be very well constructed and it would give at least a few more years of good use in an Athlon XP system. It seems to be a crapshoot these days purchasing almost any P/S in general hence the question on repair vs replacement.
  • Chris1992
    • Apr 2005
    • 561
    Re: Antec True330 P/S
    You can repair the PS yourself if you short the prongs on the power cord with a 1-million-ohm resistor and then recap. This is done to discharge all caps so you don't get a nasty shock. Are the capxon and [M] (which is Panasonic) bulged or just have stains? if panasonic is bulged I would assume it's because of the other badcaps.
    The great capacitor showdown!
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      this will not discharge the caps at all.best defense is to measure the voltage at the main filter caps and discharge them if neeeded.
      • Chris1992
        • Apr 2005
        • 561
        Huh? no wait, that was clearing CMOS. I am mixed up. Then how do you discharge caps?
        • PeteS in CA
          • Aug 2005
          • 3580
          • USA, Unsure of Planet
          You have a bridge rectifier btw the AC inlet and the HV lytics. Either discharge the caps directly if you have access to their terminals or indirectly at the bleeder resistors that are in parallel with the lytics (typically 22K-100K parts, one across each lytic).
          PeteS in CA
          • Rainbow
            • Aug 2005
            • 1372
            If you leave it disconnected overnight, it should be safe. In all AT/ATX PSUs I've seen, the capacitors discharged in a couple of seconds.
            • Chris1992
              • Apr 2005
              • 561
              Okay. Now i know and know that the 1megOhm trick is for CMOS and CMOS only.
              • Mustang
                • Dec 2003
                • 203
                Those 2 caps are just stained. Sounds like I would need to replace the 2 1650uF caps and probably 3 1000uF caps (also Fuhjyyu) then pray a lot hehe. Since the PS went "pop", could there be other parts that might have fried beside the caps?
                Thanks for everyone's help on this problem!
                • Chris1992
                  • Apr 2005
                  • 561
                  Replace all Fuhjyyu and Capxon. Since the 1650uF parts are a rare value, replace with 1500@16. That's not much loss and you have a 20% tolerance anyway.
                  • AK0R
                    • Mar 2005
                    • 204
                    Or use 1800uF@16V or 2200uF@16V if they'll fit. Digi-Key has both, in two different diameters.
                    • Mustang
                      • Dec 2003
                      • 203
                      I'll replace the bad c(r)aps as well as the questionable ones and hope for the best.
                      On the aside, this was my kid's pc. At 1st glance I figured he downloaded some trash of the internet, caught a virus or some adware etc..gave him hell and all that stuff parents do..hehe. In the end it wasn't an irresponsible kid on his pc but an irresponsible manufacturer shaving a few pennies off the most important part of someone's pc. It's 1 thing if just the ps goes bad but in some cases it takes a few other pcs of hardware with it like a hd that won't boot because the boot sector is corrupt etc etc. So much for ISO certification whatever that's worth.. sorry for the rant.
                      • PeteS in CA
                        • Aug 2005
                        • 3580
                        ISO 9000 means that you document what you do and do what you document. It doesn't guarantee that what you document is appropriate. Putting it another way, if your troubleshooting procedure is to sacrifice chickens and read the entrails, then you better specify what types of chickens to use, where to make the incision, and include a diagram of the entrails and what to look for.
                        Did I spoil your dinner?
                        PeteS in CA
                        • willawake
                          Super Modulator
                          • Nov 2003
                          • 8457
                          • Greece
                          iso9000 9001 etc is practically BS unless you get management actively involved. many just want the paper and therefore the procedures should be as minimal as possible to gain the certification because you will be audited to see if you are following the procedures.
                          i should know being certified as internal audtor
                          one of the items i agree with is checking to see what exactly the client wants and determining if you can fulfill it before accepting the job and checking if you fulfilled it in the end. this is lost in many businesses. it is important to define exactly what the client wants and checking off each item at the end. many businesses fall into their way of handling enquiries that they have learnt over the years
                          another important item is document revision control. are the personnel working on the correct latest revision of document. is information contained in the document for them to be informed about that.
                          it could have been great but i dont value suppliers highly with that certification. required for doing business with military though
                          • PeteS in CA
                            • Aug 2005
                            • 3580
                            Doc control folks need to practically be descendants of Attila the Hun to keep some engineers in line.
                            PeteS in CA
                            • yanz
                              • Nov 2004
                              • 910
                              Hey Mustang, are you from ocforums.com? I've read about your antec psu caps blowing.. nice pics there..
                              days are so short when you actually do something..
                              • Mustang
                                • Dec 2003
                                • 203
                                Sorry for the late response yanz. That wasn't me. I guess there's a lot of mustangs in circulation
                                Can anyone post a link to a distributor's website? I still need to fix that PS. Thanks!
                                • AK0R
                                  • Mar 2005
                                  • 204
                                  Digikey: http://www.digikey.com
                                  Computek: http://www.computekinc.us
                                  If you search the forums, there is a post with all the known-good suppliers, including Allied, Newark, etc., including overseas.
                                  • Mustang
                                    • Dec 2003
                                    • 203
                                    AKOR, Thanks for the info!
                                    • Mustang
                                      • Dec 2003
                                      • 203
                                      Still haven't been able to complete the repair, waiting on a back order from digikey. I did get the 1000 uf 10V Rubycon caps in from computekinc and while in the mood to solder, replaced the same on 2 other PS's(Allied and Aspire). Both of these supplies were loaded with capxon's, fuuyou's and g-luxons. I now notice the +5v in the bios is stable as a rock! Is it a safe assumption that the 10v caps are used in the 5v circuit? Also noticed the DVD drive now auto runs straight off without having to run the tray door a few times. I dunno if any of this is related to recapping BUT, I'm really happy with the results so far even if it may just be pure conjecture
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        Still haven't been able to complete the repair, waiting on a back order from digikey. I did get the 1000 uf 10V Rulycon caps in from computekinc and while in the mood to solder,
                                        i sure hope you didnt intentionally order RULYCON caps!
                                        • triplefour
                                          JVC LT-55UE76 has bulged cap on power supply, spilled electrolyte.
                                          by triplefour
                                          got this tv from a friend who got a new one and didnt want to bother repairing this one.
                                          he said it sometimes would just flash color patterns.
                                          and sometimes it would just work
                                          i figured it had some intermittent mainboard issue.
                                          i stored it at home for a while before looking at it
                                          when i plugged it in for the first time, i heard some popping noises
                                          and then a big cloud of white smoke came out of the back of the tv!
                                          i noticed the smoke didnt actually smell like anything. not like when an IC blows.
                                          i unplugged it and took the back off and discovered...
                                          12-18-2022, 12:38 AM
                                        • sirpsychol
                                          Antec Earthwatts EA-380 smd element type/value
                                          by sirpsychol
                                          While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                                          09-03-2023, 07:58 PM
                                        • CWEastwood
                                          Antec Smart Power SL300S capacitor replacement.
                                          by CWEastwood
                                          I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                                          The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                                          I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                                          Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                                          03-25-2023, 12:18 PM
                                        • s_henya
                                          Antec VP-600P and NE550M dead
                                          by s_henya
                                          Got in these 2 nice PSUs, both died after power surge.
                                          Both seems to be suffering from the same fault.
                                          Blown main fuse
                                          Shorted N mosfet 550v
                                          VP-600P: 5R280CE short between GDS
                                          NE550M: MDF18N50 short between GDS
                                          In terns of board layout these seems pretty identical.
                                          From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                                          I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                                          Is it worth to try and replace the mosfets? is there a chance that the...
                                          12-03-2024, 10:00 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
