I have an HP Z600 Workstation that worked fine until somedays ago. Now, it won't power up and the green led on the PSU is not turning on.
Pulled out the PSU from the chassis and opened it. No visibile signs of burned ICs from what i see.
The model of the PSU is a Delta DPS-725AB, and the PCB is a DPS-725AP.
I've made some high res photos that are attached.
I've done some general testing and I found IC902, that is a TNY279PN, was shorted (I think): drain-source resistance was about 2-3 ohms.
I've a brand new TNY279PN at home so I tested it and the drain-source resistance was about 5.5Mohms. Thinking it was the problem, I replaced the IC on the PCB, but the PSU still not working.
I've replaced also the 100nF capacitor on the BP/M line but nothing changes.
Voltage on the main big caps is about 322V, I marked it on the photos.
Other reads over the TNY279PN:
EN/UV voltage: 1.89V
BP/M voltage: 1.80V (from the datasheet I've read that it should be over 5.85V, I'm right?)
Main cap positive-Drain: ~320V
Drain-Source voltage: 3.90V
I think this circuit with TNY is for 5Vsb but I'm not sure, can you confirm?
If so, the D-S voltage should be ~5V
What can be the problem, and what could I test to find it with you?
Thanks all in advance
If so, the D-S voltage should be ~5VWhat can be the problem, and what could I test to find it with you?
